Carbon Fiber Goodness
Old Aug 31, 2012 | 10:09 AM
masonh's Avatar
i guess it's 200mph now
Old Sep 1, 2012 | 05:29 AM
Craig King's Avatar
How much does the stock driveshaft weigh?
Old Sep 1, 2012 | 09:53 AM
masonh's Avatar
i have read anywhere from 38lbs to 43lbs so i am not totally sure,but i will weigh mine and post it here.
Old Sep 1, 2012 | 10:07 AM
masonh's Avatar
i just weighed mine and it comes in at 39lbs with the carrier bearings,but i will also be removing the carrier bearing housing for this one piece unit.i would guess the housing weighs in at 2-3lbs each so that is probably where the 43lbs estimate comes from.
so with this DS you will probably save 25lbs total with close to 20lbs of it being rotational.cost is higher than the 2 piece aluminums but the weight savings is quite a bit greater.
Old Sep 2, 2012 | 05:38 AM
Craig King's Avatar
All this talk about light weight shafts...
Old Sep 2, 2012 | 05:55 AM
06evors's Avatar
Originally Posted by smoOVE
that things so pretty you should just hang it up in your house dont even put it on. lol
That's the first thing I thought. That thing is peerty.
Old Sep 2, 2012 | 12:24 PM
R/TErnie's Avatar
Does it really fit?
Pictures please.
Old Sep 2, 2012 | 03:03 PM
masonh's Avatar
it definitely fits,i know 2-3 guys running them and it is made specifically for the EVO.
i'll put up pics when it's installed,probably next week.
Old Sep 2, 2012 | 03:10 PM
masonh's Avatar
i'll also put up pics of the housing we re-move and how much/what part of it.mock-up looks like it will fit with minimal clearance of the housing.
i think they have a 2 piece for guys that don't want to alter the car.
Old Sep 2, 2012 | 09:49 PM
R/TErnie's Avatar
Please explain what housing you speak of? Do you need to grind spot welds to remove this "housing"
I'd like to see installed pics because I know that the dss single piece shaft supposedly didn't fit. So please show me what you did... Pictures would help a ton. Thanks
Old Sep 3, 2012 | 05:29 AM
94AWDcoupe's Avatar
hope everyone realizes one piece shafts can only be used when engine and diff are using solid mounts. and i dont mean harder than stock mounts. they need to be locked down solid. only movement left for shaft to deal with would be chassis flex.
Old Sep 3, 2012 | 08:37 AM
R/TErnie's Avatar
^ thanks.... From what I remember talking to frank was that no a 1 piece shaft really isn't reasonable.
Old Sep 3, 2012 | 09:58 AM
Pirana's Avatar
Subs for more info...
Old Sep 3, 2012 | 11:09 AM
masonh's Avatar
not sure who frank is?
Old Sep 3, 2012 | 08:29 PM
03whitegsr's Avatar
Double post
