Clutch, is mine gone????
Old Feb 2, 2004 | 09:57 AM
Stop&TurnFreak's Avatar
Well, I think it happened. After a few track events, everything seemed fine. I was driving around with my nephew, and he was begging for a launch. So I revved to 4500-5000, dropped the clutch, massive awd dig, tires finally stopped spinning, grabbed, and then the car lurched forward for about 1 second, then RRRRRREEEEEEEEEVVVVVVVVV, and then grab again? I thought if the clutch was failing, it would have failed in every gear, but it was fine, the rest of the pull? I just thought I hit it again with my foot, because it did so well. HOwever, when I stopped, it STUNK, but there was no difference in driving, so I thought it was a fluke. Did I hurt this thing, or is this normal for a pull like that? I only track this car, and very rarely does it hit the street. So I am thinking Iam just paranoid. If I had a problem, what would it be like?
Old Feb 2, 2004 | 11:29 AM
Fourdoor's Avatar
Re: Clutch, is mine gone????
That wasn't the wheels spinning in first gear, it was the clutch. As long as the clutch is fully engaged before you go WOT it should last for a while for daily driving....but don't do any more launches untill you have a new clutch sitting at home waiting to go in the car.
Keith
Old Feb 2, 2004 | 12:04 PM
boomn29's Avatar
Clutch dump at 5k = buying new clutch.
Old Feb 2, 2004 | 12:16 PM
boostedwrx's Avatar
clutch dump at 5k = ok if you slip it just a sec
Old Feb 2, 2004 | 12:17 PM
What is a good one to go with? I don't want to spend a fortune, and I am NOT going to the strip, just open track.
Old Feb 2, 2004 | 01:03 PM
broeli's Avatar
ACT
Old Feb 2, 2004 | 01:44 PM
Fourdoor's Avatar
Originally posted by broeli
ACT
I agree, for street and track use without much expense the ACT is the way to go.
Keith
Old Feb 2, 2004 | 01:46 PM
leopoldo's Avatar
start saving now and just dont push your clutch drive normal and get act.
Old Feb 2, 2004 | 01:54 PM
So would open track events, count as pushing? I don't launch hard, it is pretty much WOT after the clutch is out.
Old Feb 2, 2004 | 01:57 PM
Ryanmcd3's Avatar
In Timeout
I have done a few lapping days in the evo and the stock clutch is fine if you know how to drive. Also I am putting down about 350whp and can spin all 4 tires if I floor it in 1st without dumping the clutch
DEL TURBO's Avatar
My clutch is still ok, but I'm planning to upgrade to ACT. A good way to test your clutch is to stomp on the gas from a slow, 3rd gear roll. If the clutch is shot, you'll feel it slipping.
I was quoted $500 for clutch installation. You can pick up the ACT clutch for around $550.
Old Feb 2, 2004 | 01:58 PM
Z1 Performance's Avatar
easiest way to check is put the car into 4th or fifth at around 1500 rpm....then floor the car...if the revs build and car goes nowhere, its the clutch...if not, the clutch is still in ok shape.
Old Feb 4, 2004 | 10:13 AM
Thanks.
SyncdLancer
Sep 29, 2016 04:39 PM
sUp3rSiMpLiCiTy
Oct 14, 2015 01:17 PM
bostonhatcher
Jul 19, 2009 06:41 AM
snafufx
Dec 23, 2008 06:48 PM
Tek3Evo
Aug 14, 2008 01:25 PM
