First gear whine
Old Sep 10, 2012 | 12:56 AM
vicariousthrill's Avatar
First gear whine
Well recently i changed my fluid in my transmisson with redline product and saw metal shavings on a my drain bolt. I don't know what is considered to much shavings to be abnormal. Also i have a whine in first gear only starting around 2k rpm and up and slowly disappears. I haven't change my transfer case fluid yet or differential, but probably will this week. I have read other post that first gear whine is normal on evo's so just trying to get more info from everyone. I do have a ACT clutch that does makes noises at idle with the clutch pedal out and goes away when pedal is pushed in, and the famous coffee grinder noise on decel people talk about. Any info anyone has will be appreciated. thank you
heres a picture Name:  photo-1.jpg
Here is a video clip of my noise
http://www.youtube.com/watch?v=kYOH-...ature=youtu.be
Old Sep 10, 2012 | 01:11 AM
Piro Fyre's Avatar
First gear whine is completely normal.
And the metal shavings, it really all depends on how long you went without an oil change. Of course, longer you leave it in there, the more build up the magnet plug will have. That right there though, looks a little more then normal but like I said, it all depends on the millage of that oil change.
Old Sep 10, 2012 | 07:01 AM
PatricksEvilEvo's Avatar
It seems to me like the first gear whine gets louder the more and harder I launch mine. My 1st didn't grind until this last Wednesday at the drag strip.
Old Sep 12, 2012 | 12:35 AM
Also when taking off on a incline if i dont release the clutch quick enough it makes a loud rubbing type noise untill i fully release the clutch and gas it. really annoying, what could be causing this issue.
Old Sep 12, 2012 | 03:44 AM
xbattousai's Avatar
Wow that is some serious build up, I'm doing all my fluids this weekend too. Hope its not that bad.
Old Sep 23, 2012 | 05:03 PM
I'm planning to get a new clutch soon and was wondering if they can fix this whine in first?
Old Sep 23, 2012 | 07:02 PM
jholla's Avatar
I also notice mine getting a whine in first after a handful of launches... But I may just be being **** lol.. Other than that mines solid ill prolly do a Change of fluids
Old Sep 23, 2012 | 07:04 PM
Frew's Avatar
Why worry about it? Other owners concur that it is normal, if you start getting grinding or something along those lines then worry.
Old Sep 23, 2012 | 07:08 PM
sho669's Avatar
The gear needs to be replaced to fix the whine.
It's normal like stated above and is caused by wheelhop/launches most the time.
Old Sep 24, 2012 | 10:49 AM
Tech/Sales@EM's Avatar
Similar thing happened to a Speed6 here. Seal was leaking from the output flange and pulled the drain plug and metal shards and shavings were covering the oil. The transfer case was toast and made a whine noise. The bearings were shot and the gears were starting to wear more abruptly.
Old Sep 25, 2012 | 10:28 PM
but did you only have wine in first gear?
Old Sep 26, 2012 | 02:19 PM
Evophil's Avatar
mine has 1st gear whine also
Old Sep 26, 2012 | 05:27 PM
How bad is the whine?
Old Sep 26, 2012 | 09:12 PM
JohnDoe1984's Avatar
Someone correct me if I'm wrong but it's my understanding that the evo 1st gear whines because it is straight cut like most reverse gears for extra strength and the other gears are not. It gets louder if it's damaged but it should be a little louder than the other gears.
Old Sep 26, 2012 | 11:37 PM
I've read that in many post, but i really dont think its straight cut =/. Im just wondering how hard it is to fix it.
