Greddy Profec B Spec2 Issues
Old Mar 23, 2004 | 10:54 AM
  #61
Evo11V's Avatar
Veteran: Army
bonus sure ya have it installed correctly? you have all the caps off the boost solenoid? My friend had the same problem with his and he forgot to take teh cap off one of the ports on thes soleniod. But even still this unit spikes i think because of that faulty diod.
Old Mar 23, 2004 | 11:35 AM
  #62
MrBonus's Avatar
The boost solenoid is NOT connected, in any way, to the wastegate actuator. I left the one tube from the solenoid connected to the intake but I don't see how this could have any effect boost.
Old Mar 23, 2004 | 12:07 PM
  #63
zstryder's Avatar
Ummm... why don't you try taking that hose off and capping the nipple on the MAF pipe. Given the frustration you have had with the Profec (which seems to be more than anyone else) I would give that a try. When in doubt, cap off anything not in use unless specifically instructed to.
And like Evo11V mentions, did you take off all the plastic caps on the profec's solenoid? (not the stock) There were 3 clear plastic caps, and all of them need to be taken off.
Old Mar 23, 2004 | 12:13 PM
  #64
MrBonus's Avatar
I didn't install it. I'll check them.
Anyway, the unit is holding boost now that I've shut off the Peak Hold display. Strange. I'm still selling it.
Old Mar 23, 2004 | 12:18 PM
  #65
MrBonus's Avatar
Aren't I a horse's ***?
There's a plastic cap on the "NO" port. Does anything need to be put in that hole once the cap is removed?
Old Mar 23, 2004 | 12:26 PM
  #66
zstryder's Avatar
Nope. You know what you should do now? Go run your car.
I assure you the response will be infinitely better. I helped another guy troubleshoot tuning, only to find out his NO port was capped too. Now the thing runs like a champ.
Old Mar 23, 2004 | 12:28 PM
  #67
MrBonus's Avatar
Thank you and Evo11V.
If I ever meet either one of you (I'm sure I will), I owe you both a beer.
Old Mar 23, 2004 | 12:38 PM
  #68
zstryder's Avatar
No problem man! Tell us how the car feels when you get the chance - also, psi mode should now be no different than bar, and peak hold should work just fine (and will be helpful for tuning!).
Old Mar 23, 2004 | 03:34 PM
  #69
MrBonus's Avatar
I pulled out the cap and ended up having to lower my duty cycle from 70% to 45% and the spool up is RIDICULOUSLY faster than before.
It's holding steady (I went for a 30 minute drive to check out boost in all gears) with a slight .5 PSI fluctuation when it hits peak boost then it holds. There is NO spiking whatsoever and it sits right at 1.41-1.42 bar.
Old Mar 23, 2004 | 03:49 PM
  #70
zstryder's Avatar
Awesome!
Now you need to go beat whoever installed the thing for you for not following the instruction manual.
Old Mar 24, 2004 | 11:12 AM
  #71
Evo11V's Avatar
Veteran: Army
There ya go! Thought that cap was on. Now i just have to get my unit fixed since i have one of the faulty ones.
Glad I could help...
Old Mar 29, 2004 | 05:58 PM
  #72
watchout's Avatar
Just a quick question. Aren't you supposed to use the NO port when installing on an Evo?
Old Dec 21, 2005 | 05:55 PM
  #73
d_rock27's Avatar
preofec b
im gonna try to switch it to bar
EGbeater
Jan 11, 2010 06:27 AM
IMR-TIM
Nov 26, 2005 04:27 PM
PocketAces
Oct 31, 2004 11:16 AM
JaMa
13
Jan 21, 2004 07:40 AM
bpclements
Nov 24, 2003 12:51 AM
