Air coming out of engine during boost leak test. Stock turbo
Hi All,
I was performing a boost leak test and found that there was air coming out of the engine from the valve that goes back into the intake. I've read a lot of mixed responses on why this is happening:
Oil seal in the turbo isn't sealing since the engine isn't on. (though I've heard this is only non-stock turbos)
Valve seals are bad
Piston rings are bad
PCV valve is bad (checked this. No air was entering the engine from the valve)
it's just supposed to happen
I'm connecting the boost tester to the turbo (removed the intake). I left the ebc on but regardless it doesn't explain air coming out of the engine.
I've considered capping the valve during the test but im not sure it's safe to build up all that air pressure in the engine.
Car specs: evo 9 with 62k miles. Looks like I have a stock turbo I checked the numbers and the aluminum side matched up.
Mods that may matter include: All exhaust including O2 housing and headers. AEM truboost.
Car is tuned for 24 psi and seems to hit that fine. It was running rich before tuning so I'm assuming the engine is seeing less air than the MAF?
If anyone has any insight on what can be the cause please let me know
Thanks
Jon
Valve seals are bad
Thanks
Jon
So there is the pcv valve on the back left of the engine which only opens when the engine pressure exceeds the intake manifold pressure. and then there's the valve torwards the front right that connects to the intake. If I block this there will still be air pressure building up in the engine. I guess the question is: is it normal to build up significant air pressure in the engine under a boost test? I can't imagine the oil cap holding 20-30psi
the boost leak test is not to test if the engine can take pressure, its for the acessories ie; intake, intercooler piping, throttle body, fuel rail and such aren't leaking. and yes those valves you just mentioned need to be plug. i've never had an issue with my oil cap.
Okay I'm going to try this when I get a break one of these weekends. I guess worst case the oil cap or dipstick will pop off once I hit 25 psi.
Ted B
148
Jun 5, 2025 01:24 PM
supak111
Jul 13, 2023 07:23 PM
fireroasted
Nov 30, 2014 01:39 PM
SILVER SURFER
241
May 5, 2011 07:25 PM
Clipse3GT
18
Dec 16, 2009 02:48 PM
