Who's Running a Walbro (F90000267) 416LPH E85 Compatible Fuel Pump?
Old Sep 30, 2012, 07:47 AM
drb
drb's Avatar
While everyone advertises that "in overall appearance the pump dimensions are the same" as the standard Walbro 400LPH Fuel Pump, that isn't true. The 416 E85version is approximately .405" longer in overall length than the standard Walbro 400.
Has anyone installed one and what modifications did you make to the fuel pump/pump hanger?
Thanks,
Dan (drb)
Old Sep 30, 2012, 11:58 AM
way2qik's Avatar
Thanks,
Dan (drb)
I have two of these on my Buschur double pumper. There was enough clearance between the bottom of the pump and the tank. Works fine and moves lots of fuel.
Old Sep 30, 2012, 01:16 PM
maknuge's Avatar
nice to know, been wondering the same thing.
Old Oct 1, 2012, 10:48 AM
drb
drb's Avatar
Thanks for the response. I can see where they could easily be used in a Buschur double pumper due to the modifications to the fuel pump hanger.
Old Oct 1, 2012, 10:54 AM
drb
drb's Avatar
Still looking for information on what modifications anyone did to the fuel pump/pump hanger to fit a single Walbro 416. The only way I can see it fitting is to do the same type of modifications to the hanger that you do for a Walbro 400 and in addition cutting a considerable amount off of the long fuel outlet tube on the 416 fuel pump. My concern is sealing at the rubber grommet/fuel hanger/fuel pump connection if the 416 outlet tube is modified.
Old Oct 2, 2012, 06:40 PM
drb
drb's Avatar
Pictures with dimensions attached.
To make the Walbro 416 E85 fuel pump fit in the EVO VIII fuel pump hanger, without drilling through the top of it, the 416 fuel outlet tube will need to be shortened by approx. .375".
My concern is sealing at the rubber grommet/fuel hanger/fuel pump outlet connection if the 416 outlet tube is modified. You could reduce the amount that the tube needs to be shortened by using a thicker gasket to seal between the fuel pump hanger and the car body.
I'm not sure if you can cut both barbs off the fuel pump outlet tube and still get a good seal using the standard rubber grommet. If you only cut one barb off the assembly may bottom out on the gas tank.
I'm either going to hack up a Walbro 416 or just buy a Buschur double pumper and be done with it.
Old Oct 2, 2012, 06:41 PM
drb
drb's Avatar
reserved for more pictures
Old Oct 2, 2012, 10:53 PM
mrfred's Avatar
It sure looks like shortening the outlet nozzle would do the job. With the larger OD of the E85 Walbro, I wouldn't worry about the lack of barbs on the outlet nozzle if you cut them off.
Old Oct 9, 2012, 08:42 AM
Geoff Raicer's Avatar
i just put a single walbro 416 in my evo's stock cage and took some photos. it required some light plastic trimming on the top of the pump, but worked out great! ill try to post them up this week
Old Oct 9, 2012, 10:14 AM
drb
drb's Avatar
Thanks I'm interested in seeing what you did to get the pump to fit .
Old Oct 14, 2012, 12:23 AM
evoiao's Avatar
cant wait for the pics
^^thanks
Old Oct 14, 2012, 12:33 AM
tscompusa's Avatar
Dan what the hell are you doing lol. you're still fighting that fuel pump? also punch the bypass valve in on it that will help you greatly after 60psi~ of fuel pressure.
Old Oct 14, 2012, 12:35 AM
tscompusa's Avatar
you are a boss.. how well does the car run with 2 walbro 400's in there, and did you modify the bypass valves in them as well?
i know a aftermarket FPR is 100% required (atleast should be) with a 400.. how much modifications did you do to run them both? did you enlarge the siphon and stuff?
Old Oct 14, 2012, 02:45 AM
way2qik's Avatar
Tom, I didn't modify the by-pass valves at all. Just put them in the place of the 400s I already had on there. One of the 400s actually went bad on me, so I replaced both of them with these. We did measure to make sure we still had some room were the sock met the bottom of the fuel tank, and we did. The car had LOTS of fuel after the install and made over 800 at less than 40lbs of boost. 38lbs to be exact
I'm not sure what you mean by enlarging the siphon. Could you explain? You know I've got an Aeromotive pressure regulator. I have two -10 lines out of tank into a Y-block and run -8 to the front of the car and -6 return, right?
Old Oct 14, 2012, 03:47 AM
tscompusa's Avatar
The siphon.. the part in the stock housing where the 2 hoses connect to. its like a champagne color in the one pick Dan posted.
some people drill that bigger so the flow is more controllable. if you didnt have to do it then thats good. its mainly done when you try to run 2 pumps full time.
you have over 800 on that mustang at only 38psi? lol that mustang is retarded.. you will be 950 on a dynojet.
Ya so you run the Y feed with -10 lines then you run the other end of (straight hose to inline filter at -8?
i have no idea what the stock return is so i dont know.. -6 sounds right (for modified bigger).
-6 is good for 850-900 dynojet, so your -10 is good for like 1200+ id imagine.
so you put in -10 barbs on your double pumper or you had bought it with -10 barbs to begin with? mine look to be -6
Quick Reply: Who's Running a Walbro (F90000267) 416LPH E85 Compatible Fuel Pump?
