Reminder everyone, check your engine bay grounds!
Old Oct 2, 2012 | 12:21 PM
boosted91t's Avatar
This is the 2nd car I've worked on recently that has had grounding issues. This was the worst of the two, burnt the ground from the cam sensor all the way back into the injector harness and just made a mess. While the ground was melting it fused about 3 or 4 other wires together to add to the fun.
Just wanted to remind eneryone to check your grounds, and make sure you have a solid clean connection on the engine and the tranny at a minimum.
Old Oct 30, 2012 | 08:32 AM
boosted91t's Avatar
Just want to bump this one more time so everyone reads this
Old Oct 30, 2012 | 09:13 AM
211Ratsbud's Avatar
What were the symptoms preceding the lack of car running? Shuddering dtc etc?
Old Oct 30, 2012 | 09:51 AM
b16_rex's Avatar
Is this the one you were telling me about on your brothers car.
b16_rex's Avatar
Is this the one you were telling me about on your brothers car. Bump!!
Old Oct 30, 2012 | 01:07 PM
boosted91t's Avatar
Yep, and its not the first and I hate to say it but it's not the last either
Check engine light followed by some weird codes, mostly cam sensor related ect. Made me scratch my head a bit and its not my first go around with an evo
Old Nov 15, 2012 | 05:28 AM
mrboost05's Avatar
never recieved any codes when i was on stock ecu i am currently on aem tho and adding a ground seemed to have solved it for me mine only gets hot when cranking without adding that top valve cover ground the car wouldent even start.
that ground wire runs to the ss allen head bolt on the coil.
Old Nov 15, 2012 | 06:48 AM
boosted91t's Avatar
I hope thats not the only ground you are using? The next issue will be all of that current being fed to the sensors and only 1 outlet as a ground. Better put a heavy gauge wire to the trans and/or engine, as well as intake manifold.
Old Nov 15, 2012 | 07:12 AM
ihockey1's Avatar
ya this seems fairly common on modded evos for some reason, mine has melted 3 times and on the third time i got angry and tore the whole harness apart and separated that stupid ground so it wasnt touching anything lol
Old Nov 15, 2012 | 10:48 AM
mrboost05's Avatar
No sir I have 2 gauge wire going from the tranny to the body and 2 gauge wire on the back of the block to the body that little wire is only there to replace the oem one that ran to the valve cover my question is just why was it getting hot and only during cranking my batt is in the trunk and fuse box in the glove box I thought I had made a mistake some where.
Old Nov 15, 2012 | 10:52 AM
mrboost05's Avatar
Ihockey1 nice to no its a wide spread problem did you trace that ground all the way back ? Just trying to figure out why I had no problems in the oem location.
Old Nov 15, 2012 | 10:57 AM
SilverShadow03's Avatar
This is a good read and I remember reading a little more about it in previous threads....
How many grounds are there on our evos and where exactly are they? This would help a lot of us out so we know where to look and check for good contact.
I wouldn't mind checking them out for good contacts this weekend (on my evo). I have an evo 8.
Thanks for posting!
Old Nov 15, 2012 | 11:42 AM
ihockey1's Avatar
it grounds the coil packs but i couldnt trace it back further than that, i still dont know why it shorts and melts because without fail it is showing signs of melting, but now i have it separated so i can keep an eye on it. But now i have a mild wire tuck so i guess something good came out of it melting
Old Nov 15, 2012 | 06:55 PM
mrboost05's Avatar
It does not sit well with me random stuff just melting for whatever the reason i am no electrician tho
Old Nov 16, 2012 | 06:02 AM
nightwalker's Avatar
And everyone said my 2 gauge ground kit was worthless.
