Engine misfire
Old Feb 4, 2004 | 05:42 PM
hotrod2448's Avatar
Angry Engine misfire
I need a little help from some of you fine people on this forum. My Evo has about 11,000 miles on it. The only engine related mod (if you could call it that) I have is a K&N drop in filter. All of the sudden my has picked up what seems to be misfire. It is only noticable in third and fourth gear between 3700 and 4300 rpm when accerating. It hasn't triggered a C.E.L. yet and I don't believe it is the engine pulling time. I have scheduled an appiontment at the dealer but, I was wondering if anyone had any ideas. BTW I don't believe it to be bad gas or anything else mechanical because it consitently happens in just those gears and in that RPM range or atleast that is the only time you can notice it. Thanks in advance for any help.
Old Feb 4, 2004 | 05:56 PM
ChrisS.'s Avatar
Maybe dirty injectors, or is it really cold out?, you could be hitting fuel cut. Other than that, im not sure.....
Old Feb 4, 2004 | 06:48 PM
Stock's Avatar
check your spark plugs
check the coilpacks with a voltmeter soo if they are in spec.
did you get a MIL ?
Old Feb 5, 2004 | 03:31 PM
hotrod2448's Avatar
thanks for the input I went ahead and ordered some denso iridium plugs last night just to be safe. No MIL. Does anyone have the specs on the coil packs?
Old Feb 5, 2004 | 03:57 PM
Stock's Avatar
the resistance value should be between 8.5 to 11.5 ohms
according to the Evo FSM
Old Feb 5, 2004 | 03:59 PM
EvoVIIIGuy's Avatar
I am haveing an identical problem. You get on the gass in 3rd or 4th and it clunks like the engine skipped and then just keeps on going.. no CEL because of it either, it has only done it when it is below 45 outside! let me know what the dealer says it is?
Old Feb 5, 2004 | 04:09 PM
UFO's Avatar
UFO
Mine was falling flat on its face going into 4th gear at redline. I took the plugs out on Saturday and jumped in the beater to go get some Denso Iridiums. 3 parts stores later and I still couldn't find a sinlge iridium plug compatible with the Evo and the Denso dealer couldn't order them either. Anyway, I digress... Got home and decided I'd check the gap before I put them back in. 2 plugs were right at 0.026, one was at 0.029, and the last was 0.030. Stock plugs, I might add. Re-gapped the 29 & 30 to 0.026 and took it for a spin: No more missing going into 4th. So, pull your plugs and check the gap first.
Old Feb 5, 2004 | 06:09 PM
hotrod2448's Avatar
I was a little suspicious of the plugs, quite awhile ago I took the car in for the recall with the seam sealer and when I did they asked if there was anything else to look into. I told them it was idling a little rough, so they did a compression test. Which makes me wonder if the tech screwed up the gap on one of the plugs, or if they just put in new plugs and never got the gap right. That was quite awhile ago though and this has just started recently. I have already made an appointment at the dealer so I'll let them look into it to make sure there isn't anything more substantially wrong and post back here with the results.
Old Feb 5, 2004 | 07:05 PM
limey's Avatar
Nope, not the plugs.I have changed plugs and I have experienced fuel cut in another instance, this is an anoying misfire when at 1/2 throttle...from what I am reading this is a common problem
Old Feb 5, 2004 | 07:09 PM
mitsuorder's Avatar
I am getting it now and boost is only reading at 15psi
Old Feb 8, 2004 | 07:26 AM
hotrod2448's Avatar
According to the dealer it is the throwing the po300 misfire code. They said that they can fix it but, have not yet because they wanted me to take out my turbo timer to insure that there is no warranty issues when turning it into Mits. corporate. Which I thought was very considerate of them.
johnashton11
11
Sep 13, 2019 01:23 PM
pukka
Jun 25, 2013 11:13 AM
MikeyLeblanc
Feb 1, 2008 08:15 PM
ExViTermini
AEM EMS
11
Jan 3, 2008 09:42 AM
J!n K@z@mA
Jan 19, 2006 02:55 PM
