Ef3 vs Fp BB red on 93
Old Oct 23, 2012 | 08:35 PM
GTijoejoe's Avatar
Originally Posted by JohnBradley
Nothing wrong with journal bearing, they just dont handle momentary oil starvation very well. That is one of the factors that prompted the switch to BB center sections. There is however a definite difference in transient response between the 2 that I have seen.
bingo...
I've had journal bearing turbo's last over 50k....
Anyways... I'm leaning for the EF3 this spring w00t w00t!
Old Oct 25, 2012 | 07:53 AM
zenoise's Avatar
Well after a DUNG ton of research I have decided to go with the FP red. Super reliable plus great transient response ill take that any day. Plus i have read alot and seen that Jb turbos dont lubricate well under high G scenarios which high turbo rpms mixed with little oil = fail. BB red all day
Old Oct 25, 2012 | 08:33 AM
Kracka's Avatar
People seem to forget that all factory turbochargers from Mitsubishi have been journal bearing. There are still plenty of StarQuests and DSM's running around on the stock turbo beyond 100k miles, some even 200k+, plus countless other turbo cars such as Omni GLH's. There is nothing wrong with journal bearings; like anything else, care for it properly and it'll last for a long time. Turbochargers are not a maintenance or replacement part, they're designed to last a long time, journal bearing or otherwise. 23k miles and counting on my EF2 journal bearing
Power-wise, on my old IX power was within 3whp peak between the BB Red and EF3; both easily 500+ turbochargers on E85.
Old Oct 25, 2012 | 08:41 AM
zenoise's Avatar
Jbs are good. BBs are better.
Old Oct 25, 2012 | 08:43 AM
Kracka's Avatar
As well they should be for the cost differential.
Old Oct 25, 2012 | 08:46 AM
1meandsm's Avatar
i wouldnt do the map ef3.. mine took a dump on me and by dump i mean snapped the shaft clean in half and dug the turbine wheel into the housing...
Old Oct 25, 2012 | 09:11 AM
zenoise's Avatar
And who said they have never heard of any problems with the EF3???
The guy doing my install has built ALOT of Evos and he said to stay away from the Ef3 as well cause he has seen two of them go to hell rite after install. He directed me towards FP and yes the price is around 6-700 more but Id pay that anyday to keep my car running everyday and not have down time from having to send the EF3 back into Map.
Old Oct 25, 2012 | 09:44 AM
CBRD's Avatar
well put!
informative thread for sure-
cheers
cb
Old Oct 25, 2012 | 09:45 AM
ChrisCarey's Avatar
Would you mind PMing me your name sir, I would like to look into this further as I am not aware of any turbine wheel failures. I tried searching through your old posts for info, but all I found was this thread about your old FP turbo failing.
https://www.evolutionm.net/forums/ev...hite-fail.html
Old Oct 25, 2012 | 09:51 AM
gsrboi80's Avatar
FP has certainly had their fair share of failures on the stock frame units over the years. So don't be naive man do some searching for yourself
Just giving you an FYI as I have no dog in this fight I went T3 years ago and would never go back
Old Oct 25, 2012 | 09:52 AM
icmanevo's Avatar
I havn't had either turbo but am considering the EF3 in the spring... My research has netted a significant amound of reliability issues with FPs, not to mention long turn around times and such. Not to say that there aren't a ton of happy customers for both... Ive had amazing customer service and crazy fast delivery with MAP.
Old Oct 25, 2012 | 10:10 AM
CBRD's Avatar
We have ALL had turbo failures-----
plain and simple.
cb
Old Oct 25, 2012 | 11:37 AM
ETS Michael's Avatar
T3 For Life! It does have an initial up front cost, but you can sell most of your old modifications pretty easily on the board.
What you gain.
Larger Turbine Housing
Better Turbocharger Options (In My Opinion)
Pull To Redline (No More Mountain Graphs)
Larger / Ported Compressor Covers (Anti-Surge)
Better Transient response between shifts (Allows you to hold more boost through the shift - (Ball Bearing)
Larger Downpipe
External Wastegate
Man.. I feel like I can go on for days. We have options for spool from 3800-6000, depending on horsepower goals.
Good Luck Man!!!
Michael
Old Oct 25, 2012 | 11:51 AM
zenoise's Avatar
And why does ETS sell a BB turbo???
Old Oct 25, 2012 | 12:27 PM
I do sell BB turbochargers and JB turbochargers for the guys on a budget or automatics.
