Do you need to remove the Flywheel pins in order to get it resurfaced?
Old Oct 28, 2012 | 08:35 AM
Randal's Avatar
Guest
So I removed my flywheel and noticed it has 3 pins sticking out that go into the pressure plate once together. Is that something I need to remove before sending it off to resurface or do they handle that?
Attached Thumbnails Do you need to remove the Flywheel pins in order to get it resurfaced?-image.jpg
Old Oct 28, 2012 | 08:36 AM
Yiyo's Avatar
Yes
Old Oct 28, 2012 | 08:45 AM
Randal's Avatar
Guest
Originally Posted by Yiyo
Yes
Yes what?
Old Oct 28, 2012 | 08:55 AM
Yiyo's Avatar
You can do it. If they do it maybe you have to pay extra
Old Oct 28, 2012 | 08:59 AM
Randal's Avatar
Guest
But if its removed and inserted again wouldn't it vibrate lose after a couple thousand miles and cause havoc in the clutch housing?
Old Oct 28, 2012 | 09:15 AM
n2oiroc's Avatar
just let the machine shop deal with it.
Old Oct 28, 2012 | 09:18 AM
Yiyo's Avatar
Exactly
Old Oct 28, 2012 | 11:21 AM
Randal's Avatar
Guest
Will do. Thanks
Old Oct 28, 2012 | 01:29 PM
todd6027's Avatar
nope they wont vibrate loose they are interference fit
Old Oct 29, 2012 | 07:32 AM
Randal's Avatar
Guest
I just went to get the flywheel resurfaced and the guy tried removing the pins and it did not come out, his tool even broke. He said the best thing to do is to cut it off. Is that okay since it's just a guide? Will I have any problems?
Old Oct 29, 2012 | 08:29 AM
lostsoulsevo's Avatar
just buy a streetlite act flywheel but to answer your question, don't cut them off
Old Oct 29, 2012 | 08:48 AM
batty200's Avatar
your flywheel is warped. Just buy a new one.
Old Oct 29, 2012 | 09:08 AM
Randal's Avatar
Guest
So o got it resurfaced with the pins out. He said they took off 6 thousandths of an inch off. And it looks brand new.
Old Oct 29, 2012 | 09:17 AM
Randal's Avatar
Guest
Is it still usable? I don't see why not
Old Oct 29, 2012 | 11:13 AM
todd6027's Avatar
yes
