US made forged pistons and rods for EVO8?
Originally posted by Zeus
...just remember to measure the cylinder bore closely (and piston to wall clearance of course). I'm not a fan of not going at least with a slieght over bore piston to clean up the cylinders and assure a good seal. Of course some numb nut is going to come along behind me and say you don't need to and how many engines THEY have built
with no problem...
with no problem...
What about my question on wether pistons and rods for the late model turbo Eclipses would fit the EVO? Anybody that could verify on that?
Originally posted by Wadzii
he should at least go with a factory overbore.... imo, never put new rings in an old bore. especially one that is gona be making some power.
Originally posted by EVOVII_SWE
Then what do you consider as an "old boar"? The engine has maybe 10 minutes of running time on it.
A used bore period... See, it's not so much just the bore. The new pistons are going to have different dimensions... that may, or may not match the bores to correct clearances. In short, he may be building the block again if you don't run the proper size pistons in the properly prepared bore. If the bores and pistons do Mic out correctly, you will need to get a good hone and Mic them again.
Then back to the old question, will rods for the later turbo Eclipse fit the EVO?
I'm not saying it won't work, I'm saying I'd rather not. If everything measures out ok, try it... sounds like your not afraid to tear it down again anyway if it doesn't work out.
If I were to send one of the stock pistons to say JE and ask them to make a forged replacement piston with the exact same measurements would that work you think?
I mean, if you look at stock cylinders and pistons no way they are matched individually at Mitsubishi factory. So if you custom make a piston with the exact measurements it couldn't be worse than stock could it?
Otherwise, just changing the rods would probably work ok with that kind of power (350-360 crank HP), as long as I can find some that fits of corse.
Call Buschur Racing... No need to fool around. (And get advice on how you should replace your crank when you upgrade your pistons/rods
https://www.evolutionm.net/forums/sh...threadid=55509
) https://www.evolutionm.net/forums/sh...threadid=55509
marcouxa1
Lancer Aftermarket Forced Induction Tech
55
Jul 31, 2025 08:23 AM
evilempire76
Sep 9, 2007 01:51 PM
blackevo110
82
Aug 1, 2006 08:39 PM
