Evo VII - Pulling Left
Old Nov 9, 2012 | 06:39 AM
Se7ve's Avatar
Had an issue with my JDM VII for a while now and wanted to see if anyone else had encountered a similar issue.
When on boost the car pulls right and off boost the car pulls left. The steering wheel literally 'snaps' left when the throttle is lifted.
Also the front of the car feels 'floaty'. When the throttle is floored the steering wheel jumps left and right, almost like there is no contact with the road surface.
It has been suggested that the front diff (ACD) may be at fault.
Has anyone experienced this kind of issue caused by the front diff? (or any other cause??)
Old Nov 9, 2012 | 10:18 AM
barneyb's Avatar
No, just a theory here. Toe is set to zero because, on acceleration, the front will toe in a little and, on deceleration, the front will toe out a little. The rubber bushings will allow some movement. A loose part will cause more of this and maybe what you are describing.
Old Nov 9, 2012 | 05:37 PM
Se7ve's Avatar
Thanks for the reply Barneyh but I've had the toe, camber and caster corrected (I've done it myself with a full laser system) and all are equal and within tolerance
Old Nov 9, 2012 | 08:31 PM
slowonder's Avatar
had this happen on cars with the similar style lower control arms. check the rear bushing make sure it is good along witht he ball joints.
Old Nov 10, 2012 | 08:17 AM
Se7ve's Avatar
Thanks slowonder. I have completely polybushed the rear and have checked the ball joints.
I will be investigating the drive shafts and output shafts today....
Old Nov 10, 2012 | 12:12 PM
legacydestroyer's Avatar
Only other thing I can think of, possible engine or trans mount bad/shifting. Causing the "torque steer" affect. Just a possibility. Good luck bro.
Old Nov 10, 2012 | 05:15 PM
Se7ve's Avatar
thanks LegacyDestroyer.
I will replace the mounts in the near future as a matter of course. I did have a bad motion from the rear (not like this issue) before I polybushed, so maybe mounts are contributing
DonHugo
Feb 11, 2014 06:14 AM
TurboTJ
14
Jan 8, 2014 11:05 PM
evobewbie
May 23, 2013 07:11 PM
kevin10
Lancer Engine Tech
Mar 31, 2013 09:49 PM
Evo_Someday
Driving Techniques
Jul 3, 2008 02:13 PM
