freeze plug OEM or Rubber one?
Old Nov 13, 2012 | 10:31 AM
vroomevo's Avatar
Hello, what's the downside of using rubber freeze plug? it will take me an hour to go to mitsu dealer to pick up the OEM vs local autozone has Rubber freeze plug.
Old Nov 13, 2012 | 10:38 AM
k_sheanh91's Avatar
the rubber ones are a temp fix, i.e. if you blow one out and need to get home. autozone should carry a Dorman one thatll fit the Evo, its part number 555-093.1. when you install it, use a socket that fits on the outside rim of the freeze plug and tap it in.
Old Nov 14, 2012 | 01:30 PM
gpfury86's Avatar
I would only use OEM, I have blown out several doorman brand ones. I put them in with retaining compound as well.
Old Nov 14, 2012 | 01:48 PM
FathouseFab's Avatar
Oem freeze plugs only!
Old Nov 14, 2012 | 01:56 PM
meckert's Avatar
Better solution is to find out why your pressurizing the coolent system and blowing the plug if you have gone thru several....sounds like a bigger problem then freeze plugs that pop out. headgasket maybe-- I would start there.
Old Nov 14, 2012 | 04:03 PM
gpfury86's Avatar
When u start making power with these things and spinning them hard, the block flexs and some pressure is created from the high flow of the water pump. I don't have any blown head gaskets or am pressurizing the coolant system from something that is wrong. I put oem freeze plugs in and haven't had a problem since, so I would just take my advice and past headaches and use oem plugs . I've seen the same problem in other blocks that are making 500+ hp when they didn't have oem freeze plugs in.
Old Nov 14, 2012 | 07:22 PM
okevolutionVIII's Avatar
If there's a NAPA near you, they have a ton of different size freeze plugs. They just need a diameter of the one you need.
ridenrunwv
Jun 10, 2015 10:41 AM
Drifto
60
Jun 13, 2014 09:48 PM
snafufx
Oct 30, 2013 12:12 PM
mcjallen
Nov 1, 2011 02:37 AM
dsevo
31
Oct 7, 2009 10:45 PM
