Question about 2.3l timing
Old Nov 15, 2012 | 03:27 AM
Eno-Evo's Avatar
Anyone ever do timing on a 2.3l? I'm wondering what the degree marks get set to on the adjustable cam gears ?
Old Nov 15, 2012 | 05:00 AM
tsidrift1's Avatar
Set the marks at zero, unless you are properly degreeing your cams.
Old Nov 15, 2012 | 08:39 AM
Eno-Evo's Avatar
Ok so technically you time it the same as 2.0l
Old Nov 15, 2012 | 10:18 AM
importrepairguy's Avatar
What Block are you using?
If 4G64 Block w/ 4G63 Head then Set both gears @ -4Degree's (RETARDED 4DEG on Both IN/EX) & that should be TDC. My understanding Block deck height is 6mm Taller.
If using a 2.0 Block then TDC has not changed (0 DEG on Both IN/EX) unless you degree your cams w/ proper tools.
- Hope this helps
Old Nov 15, 2012 | 10:06 PM
Murf's Avatar
If using stock gears and your cams don't require much degree work, use the stock time marks.
evilbada
Automotosports - Illinois
46
Aug 11, 2008 09:08 PM
gtm_maxwell
Mar 31, 2008 04:02 AM
richysevo8
100
Mar 2, 2008 08:19 AM
Talonmotosports
10
Jan 7, 2007 11:26 PM
2.3 Evo 8
63
Nov 14, 2006 11:18 AM
