Timing retrad from 2.0 to 2.3L
Old Feb 25, 2008 | 04:48 PM
gtm_maxwell's Avatar
I need some help with the Timing Map.
I have install a strocker kit from 2.0L to 2.3L, what are the total timing retrad I need from 2.0L to 2.3L? -5 or -10 over the Timing Map, I am using a PowerFC Djetro...
If any one have the Map of 2.3L Timing map.. Thanks in advance...
Old Feb 28, 2008 | 02:58 PM
EvoVIII808's Avatar
not sure if anyone has that. i would say start with -5 and go from there.
Small increments is what i do.
Old Feb 28, 2008 | 04:34 PM
IC, so that's mean if we use strocker kit we need to reduce out Timing right?. As the original timing for the 2.0L will be too advance for a 2.3L/2.4L kits....?.
Old Feb 29, 2008 | 01:00 AM
EvoVIII808's Avatar
Yes i do believe this is correct, anyone can back me up on this. I am still very new to this system.
but thinking about it, i think you should be able to run higher timing since there is alot more space for ignition. Dnt quote me on this but it is worth trying to find out.
Maybe post in the AEM section, this will get you in the right direction.
Old Mar 10, 2008 | 03:19 PM
RickyLee53's Avatar
It will depend on lots of things, i can mail you my map if you like.
Old Mar 25, 2008 | 07:44 PM
Evology's Avatar
not true.. the base map that comes with the PFC worked fine with me!
Old Mar 31, 2008 | 04:02 AM
Did you stroke your engine?
Please explain, the engine map that I have at the moment can start the car but the idle are not stable when I start to give more gas...etc
My03evo
17
Jan 6, 2017 10:36 AM
jnassar89
Aug 2, 2016 06:24 PM
jnassar89
Jul 19, 2016 03:38 PM
jid2
E85 / Ethanol
159
Aug 19, 2015 11:09 AM
GT35REVO8
14
Jun 15, 2007 11:50 AM
