Anybody having trouble with their Odyssey pc680 battery?
Old Nov 23, 2012 | 11:00 AM
Thoe99's Avatar
Originally Posted by Randal
I have tried two different chargers that odyssey recommended. No luck. The warranty is a hassle. I am just purchasing a new one tomorrow.
That's because you need preventative maintenance--that is the battery tender. These batteries do not do well after a complete discharage, so you need to maintain it.
This:
http://www.amazon.com/Odyssey-Battery-OMAX-6A-1B-Ultimizer-Charger/dp/B000S16BQ8/ref=pd_sim_auto_8 http://www.amazon.com/Odyssey-Battery-OMAX-6A-1B-Ultimizer-Charger/dp/B000S16BQ8/ref=pd_sim_auto_8
Old Nov 23, 2012 | 09:20 PM
Rom's Avatar
Rom
I had constant problems with my pc680 on my Lotus... Switched to Optima red top and had the same issue a couple of times. Because I left the car sitting, it would discharge and kill the battery.
Put the pc680 on the Evo, and because we drive it everyday, it has never had an issue!
These types of battery (AGM/gel) really do not like to be fully discharged. Get a battery tender as suggested by others and it won't be an issue.
Thanks!
S.
Old Nov 24, 2012 | 03:46 PM
TommiM's Avatar
Originally Posted by mrfred
Looks like the the positive terminal is on the front left of the battery. For the battery turned sideways like a mini-battery, doesn't that make it difficult to get the positive power cable attached?
Ya I assumed this was also with a relocated battery, not one in the oem location, sorry.
But its still possible to use in oem location, just takes a little extra work. You can get some slack out of the oem battery cables by opening up the harness and re routing some of the wiring. The starter cable should have enough slack, the alternator might need to have to solder in a piece to have it reach but really isnt that big a deal.
eeevooo
Jun 4, 2017 09:32 AM
franzcars
Dec 23, 2015 11:24 PM
turboevo8
Jan 20, 2015 04:44 AM
blowngasket
Jan 26, 2012 01:41 PM
