Want to "upgrade" from my 4088r?
Old Nov 19, 2012 | 06:16 PM
KJS1820's Avatar
Right now I have a full race twin scroll gt4088r on my 2.3 and like it but want to change it out and try something else! I searched alot but didn't find much info but I am leaning towards the hta3794!How would this compare? will it have similar spool characteristics?
Old Nov 19, 2012 | 08:03 PM
MrLith's Avatar
Man that is a question I'd REALLY like to know the answer to as well, I have pondered the same thing quite a bit. If I were a betting man I'd say the GT3794R will be slightly laggier but with the potential to completely smash the GT4088R for power. You are looking for more power with similar spool I assume?
Old Nov 19, 2012 | 08:10 PM
Sharkbite2000's Avatar
^how much power are we talking about ?
Old Nov 19, 2012 | 08:21 PM
MrLith's Avatar
Depends on fuel, engine spec and how brave you are.... Boostin Performance have pushed theirs past 900whp to get into the low 8s at 170+mph which puts it into serious business territory
Old Nov 19, 2012 | 08:25 PM
Thats alot of power the most I've pulled out of 6765/.63, 840awhp on Q-16.
Old Nov 20, 2012 | 04:53 AM
KJS1820's Avatar
I always loved watching your vids Sharkbite! You built a badass car! I would like 700-750 hp at about 40 psi or less, all I run is e85 and I drive the car 3-4 times a week most of the time it is traffic but love opening it up on the highway I don't race in traffic light to light so highway is where I want my power. I think I have my car ready for bigger power maybe my 3.5 inch intercooler will have to be swapped out but everything else is overbuilt!
Old Nov 20, 2012 | 07:41 AM
spadednick88's Avatar
I have a 40r now as well. Im thinking of bumping to a 6766.
Old Nov 20, 2012 | 08:21 AM
Joshs EVO's Avatar
Actually it's funny cause I had the ETS 4088 in 2008 and then moved to the 3794HTA within in the last two yrs. Haven't had any solid numbers but when I had the 4088 I made 670 @ 33 lbs. When I switched over the first pull made 730 with the same spool. I literally swapped it right over put the car on the dyno and did a pull.
But ever since then the car for some reason never made anything past 33 lbs. I believe I have fixed the issue..LOL inside joke... But since then I have changed the motor to a 11:5:1 CR Buschur 2.4LR with STM 650 cams running E98.
The car is sitting without a tranny as it got sent off to Jacks to get some new gears put in it as well as a new clutch. So I am hoping by Jan the car will be done.
In regards to spool the car spooled just as fast with the 3794HTA than it did with the 4088. I couldn't tell a difference. Only difference will be the 3794HTA puts out more HP.
Old Nov 20, 2012 | 08:24 AM
Whats max hp on 40r? I made 620 on 32 psi with stock head and bc 272's
Old Nov 20, 2012 | 08:35 AM
jessmanEVO's Avatar
You can try running the 6766. Thats what I got on my 2.4 . I made 703 on an md only revving to 7k. I just ordered a new igniton so keep an eye out in the evo dyno threads
Old Nov 20, 2012 | 09:09 AM
Joshs EVO's Avatar
The 40R max power is 800. Also, something I didn't know when I got the 4088 is that it's been around for a long time, unchanged in the same format. Whereas the original 3794HTA has been updated with the billet wheel and is no longer a standard 37.
The 3794HTA max power is unknown right now I think. I know the AWD car did 910 and I've seen another Evo running it hit 970 @ 52 lbs on a dyna pack. So maybe with a slightly different setup it can touch 1000 HP.
The only problem with my setup is the TS will limit the highest HP limits.
Old Nov 20, 2012 | 10:44 AM
KJS1820's Avatar
Cool thanks for all the tips! I am limited to a t4 setup with a 3 inch V band out so it was a borg warner or a forced performance turbo for me! I will give the HTA3794 a try and I am sure I will like it
Thanks
Kurt
Old Nov 20, 2012 | 10:48 AM
U can get the 66/67 in vband t/4
Old Nov 20, 2012 | 12:42 PM
MrLith's Avatar
Their is no point going to the 3794R if you aren't shooting for well over 800whp imho - the GT3786HTA or GT3586HTA (or a Precision PT6466 - though I knew a million people would recommend the Precisions despite the FP probably being at least as good).
Here is a good example of how mental a 3794R can been when leaned on: https://www.evolutionm.net/forums/al...rformance.html
Owner sounds like he reckons he still hasn't made the most of what the turbo can offer, more to do with the chassis than the turbo.
Spoolin18
32
Dec 9, 2013 07:36 PM
PATRICK B.
Aug 20, 2013 08:19 AM
ETS Michael
ExtremeTurboSystems.com – WA
77
May 13, 2010 03:04 PM
giangi
97
Sep 5, 2007 11:25 PM
