need help pte6262 /6266 /6466
Old Nov 22, 2012 | 07:39 AM
eus_evo8MR's Avatar
hey buddy, i need information. my car setup :
shortblock cosworth 2.2
complete head big valve cosworth
tomei procam lash-type 270 in+ex 11.5lift
turbokit ams750R
now i want to change the turbo, what is the best setup for 1/8miles and 1/4miles?
pte ballbearing 6262 or 6266 or 6466?
Old Nov 22, 2012 | 04:11 PM
17pstockcar's Avatar
How much power do you want to make?
Old Nov 23, 2012 | 02:36 AM
AngryEvo8's Avatar
Either the 6266-6466 rule that 6262 out If you are looking to 1/4 race it alot I would suggest the 6466. Its making similar power to the 6766 with quicker spool.
Old Nov 23, 2012 | 04:54 AM
eus_evo8MR's Avatar
maybe around 650whp++ if the engine can go to 700
Old Nov 23, 2012 | 01:50 PM
Well golden rule with turbos is use the smallest turbo for your powergoal so according to that you would use the 6262 but because the 6466 spools very close to it you could choose the bigger tubo and have more room to grow.
Old Nov 23, 2012 | 05:39 PM
b16a95eg's Avatar
FWIW my 6466 somehow outspooled my 6266, not by much, maybe ~50rpm, that may not be the case on everyone's set up, mine at the time was pretty conservative with mild cams, no headwork and 9.0:1 compression.
It depends on if you want to competitively drag it or not, if thats the case, i'd go with the 6266 so you'd be able to run with the smaller turbo guys, I ran the 6466 at MAP's proving grounds and it kind of sucks being in the big dogs class with a lot of the shop cars and having the disadvantage of the smaller turbo when some are running 42r's, etc.
BUT if you're mainly building a Highway car with no intentions of competitively drag racing, go with the 6466.
Old Nov 23, 2012 | 07:59 PM
TheReal94_tsi's Avatar
You will be happy with a bb 6262.
Old Nov 27, 2012 | 08:16 AM
eus_evo8MR's Avatar
hey buddy, how much power do you make with 6466?
let me know your setup, is that car for daily use too?
Old Nov 27, 2012 | 10:34 AM
b16a95eg's Avatar
I made 709whp on a Mustang Dyno with a fairly mild set up (stock intake manifold/throttle body, no porting)
Car ran a 10.3@144 on my street tires and weighs 3210 with me in it and half a cage
I do drive it at least a couple times a week in summer, the clutch I was using was the only reason I wouldn't
Old Nov 27, 2012 | 11:12 AM
way2qik's Avatar
If its a "highway" car, he might as well just put a 6768 on the car. The added size of the turbine wheel will definitely allow the car to make a good deal more topend power.
Old Nov 27, 2012 | 11:47 AM
BURNALL_4's Avatar
Fp3586hta
Old Nov 27, 2012 | 01:19 PM
gpfury86's Avatar
I street the 6466 and I like it, just not a ton of places besides the highway were u can really string it out. My car is at the power level/setup where it's not easy to just get on it a little in town without some surrounding people knowing a car is in the vicinity and making a pull lol.
Old Nov 27, 2012 | 08:03 PM
b16a95eg's Avatar
I was just using the options he gave
Old Nov 28, 2012 | 03:42 AM
eus_evo8MR's Avatar
for hold this power 709whp, are you use standard gearbox+transfercase+diff stock from evo?
when the turbo will spool? (4500rpm or over5000rpm)
did you go with lunch for drag?
Old Nov 28, 2012 | 03:45 AM
eus_evo8MR's Avatar
hey buddy, are use 2.2L? at 5000rpm the turbo has spool?
