evo 9 turbo questions
Old Nov 24, 2012 | 08:28 AM
evo1008's Avatar
Hello i have a evo 9 turbo i wanted to know if i got it ported also a upgraded wastegate actuator and the fp comp housing what hp numbers would i be getting max on e85 or on pump i know this is out there some where had trouble finding it.
Old Nov 24, 2012 | 10:52 AM
ctfpevoVIII's Avatar
Don't waste your time just buy my old school fp green thats ported and has the 18 psi wastegate actuator. pm me if your interested.
Old Nov 25, 2012 | 10:00 AM
evo1008's Avatar
Bump
Old Nov 25, 2012 | 10:38 AM
one4's Avatar
depends on all your other mods and what dyno...
Old Nov 25, 2012 | 04:51 PM
sparky's Avatar
Low 400's, up on through high teens and even low twenties(DynoJet) are doable. There is some guy that has a freak up in the 440's, or 450's that has a recent thread in the Dyno Tuning subforum though. Although I can't seem to find that thread right now......Sorry!
The O.S. Green is only worth about 15 WHP more than the IX turbo though. I had one so I oughta know. The IX turbo on E-85 is a gem.
Old Nov 25, 2012 | 05:05 PM
sparky's Avatar
As far as the actuator is concerned I would say go with the FP HD 18 pounder if you are going to be running under 27#. Get the turbine housing ported by a reputable shop, or do it yourself if you feel it is within your scope.
Old Nov 25, 2012 | 07:08 PM
TheReal94_tsi's Avatar
The tune is what will allow it.
Old Nov 25, 2012 | 10:29 PM
sparky's Avatar
The old adage usually holds true: combination is the key, especially when attempting to extract the most power from the IX 16G turbo. It is very tuner and combination sensitive.
The real overachiever cars(powerwise) with this turbo, the virtual freaks, seem to all be MIVEC cars. The non-MIVEC Evos don't perform quite as well with this turbo. But, you already have MIVEC. As mentioned by Real94, you'll need a really good tuner. And you need to hand that tuner a car with a well thought out combination of parts.
Little things seem to count when looking to extract max power from the IX 16G: Such as a low restriction, high flow air filter/intake tube combo,a speed density conversion, a well designed O2 hsg./dump option, a suitable camshaft grind, a ported TB, a MAP V2, C.B. Extreme, or Magnus IM, a ported exhaust manifold, the FP comp housing which you already have on your list, the Garrett 4" IC core, a well ported turbine housing, and a COP ignition system, etc.
Revolution9mr
Feb 18, 2015 08:50 AM
Seenoevol
Jan 28, 2015 05:14 AM
1 evo8 1
Jul 2, 2013 03:39 PM
lostsoulsevo
19
Jul 16, 2012 10:37 PM
mike1023
Northeast Region
Sep 28, 2008 07:49 AM
