might be a dumb question
Old Nov 25, 2012 | 04:48 PM
spadednick88's Avatar
This is prob a stupid question that i should already know i just wanna make sure. Im building a 4g64 2.4 and curious where is best place to tap for my oil and water for my turbo..?
Old Nov 25, 2012 | 04:49 PM
CurseDSM's Avatar
Same place as you would a 4g63
Old Nov 25, 2012 | 04:57 PM
So the block has same ports??
Old Nov 25, 2012 | 05:04 PM
CurseDSM's Avatar
it all has the same water pipe location everything should bolt up. The thermostat housing is in the same place, the lines all connect the same way. You hook up the oil line right to the same spot in the oil filter housing.
Old Nov 25, 2012 | 05:09 PM
And the 4g64 oil pan will have same return port?
Old Nov 25, 2012 | 05:28 PM
ExViTermini's Avatar
Use everything from your 4g63 on the 4g64 with the exception of the water pump. Everything will be as it was originally.
Old Nov 25, 2012 | 05:45 PM
Awesome thanks for ur help. Also gonna be using 4g64 timing belt so will need to adjust timing as well and i think thats it. Also is it really needed to machine the head to match the 87mm bore?
danny1058
May 4, 2014 11:19 AM
nemracevoli
Mar 1, 2014 06:14 PM
bigturboevo03
Aug 8, 2013 04:26 AM
evoboy2006
Mar 23, 2013 06:33 PM
etown09
Dec 12, 2012 10:39 AM
