Buzzing/vibration at 3k RPM at light throttle...
Old Nov 30, 2012 | 09:47 PM
okevolutionVIII's Avatar
I started getting a buzzing sound at 2700-3100rpm roughly while driving normally and can't figure out what the cause is. That's what I rev to when changing gears around town so I have to hear it often. Free revving doesn't cause the same noise. I recently had the oil pan off to block off the oil squirters after one broke and had this same sound before that happened. I checked all the main and rod bearing, everything looked great.
I don't have the 2 tie bars under the downpipe installed currently meaning no chance of DP rattle, have a turned down balance shaft(race shaft), and timing is dead on. Rotating assembly is fully balanced along with a Fluidamper. I'm not sure if this noise is due to not having balance shafts but another thought is that I have solid TS driveshaft carrier bushings. Any thoughts?
Old Dec 1, 2012 | 11:41 AM
Does anyone else have deleted balance shafts that has input on what the vibrations are like in that RPM range?
Old Dec 1, 2012 | 11:45 AM
Chadilac88's Avatar
did you notice the noise after you did the balance shaft?
Old Dec 1, 2012 | 11:58 AM
Well, yeah but it was over 4 years from the time the stock engine failed to building this one.
Old Dec 1, 2012 | 06:26 PM
Chadilac88's Avatar
because generaly thats where i would start. since you didnt have this issue before then it has to be something that has changed. you made sure that you torqued all the pulleys to spec? possibly a bad pulley bearing? but start off by eliminating one thing at a time.
Old Dec 1, 2012 | 09:17 PM
xxthayxx's Avatar
My 2.4LR motor does this - balance shaft deleted. I've also notice the buzzing sound when going over 70 mph. My tuner said it was normal.
bpdean
19
Dec 29, 2015 03:08 PM
barneyb
Jun 2, 2015 06:24 PM
Hanzo
54
Aug 24, 2006 08:55 AM
fr34k
Mar 8, 2005 11:51 PM
stickybishi
Australian Forum
Nov 4, 2004 04:06 AM
