Evo without ACD
Old Dec 3, 2012 | 10:48 PM
vicariousthrill's Avatar
Evo without ACD
Well i was just wondering if a Evo without acd but adding a lsd to the front will be closer to the performance of a ACD Evo? I know for sure it wont compare but i was curious to hear from people that have upgraded to LSD. Thanks
Old Dec 4, 2012 | 05:59 AM
thepoint4life23's Avatar
Lots Of People Delete The Acd and going with a build tc and a lsd
Old Dec 4, 2012 | 06:38 AM
whiteEvo08Y's Avatar
^^^^^ XXX 2 What he said. And that what i will be doing this winter.Building my TC and Putting a LSD.
Old Dec 4, 2012 | 10:09 AM
Thanks for the info. I kinda dont like the computer deciding what happens with my car haha. I will be looking into getting a lsd for the front.
Old Dec 4, 2012 | 10:52 AM
blackflash8's Avatar
What LSD is recommend
Old Jun 15, 2013 | 08:09 PM
i would say for budget the RS diff
Old Jun 16, 2013 | 04:42 AM
KOOLER's Avatar
What I did with my 2007 EUDM Evo IX:
1) Replaced rear AYC diff with RS one (had to re-weld the rear frame as AYC and RS have different mounting points). RS plates re-built to make diff stiffer.
2) Replaced ACD with VCU transfer.
3) Removed the pump, wiring, hydraulic cabling and ACD ECU completely.
4) Re-worked drive shaft (RS one is shorter then AYC as AYC has shorter "tail"). It has one cross joint now and weights just a bit more then aluminum one still being 3 times harder to break (chromoly steel Vs aluminum). Basically I have custom drive shaft now.
5) Replaced nearly open front diff with Wavetrac.
6) Replaced GSR 6 speed transmission with a short ratio 5 speed RS one.
What I've got @ the final stage... Car is LIGHTER (that was just one point where I've removed extra weight) and this is good. Using the same engine/brakes/tyres etc setup I actually drive it SLOWER. It's not a Sony Playstation any more and ECU does not fix my driving errors with ACD/AYC setup as it did before.
Car is neutral now (more was like a rear wheel drive with open diff in the front) and very predictable.
Would I recommend doiing this to anybody? Probably not. TONs OF CASH, time and slower car @ the final step. BUT. It's fun. And I first time in my life (after Evo V JDM, EVO7 JDM, EVO8, EVO9, EVO X and EVO9 EUDM have a car with full mechanical transmission & diffs, even my Evo V had AYC I hate).
Old Jul 17, 2013 | 01:11 PM
thanks for the info guys.
MurtazaDSM
14
Mar 5, 2017 07:06 PM
manthny18
Oct 24, 2016 06:13 PM
Evopower88
Apr 23, 2015 08:42 AM
Fast 1
Oct 14, 2011 04:08 PM
MikeColangelo
May 25, 2009 03:06 AM
