02 sensor wire extender?
Old Dec 5, 2012 | 02:37 PM
BlowMeOff's Avatar
Exclamation 02 sensor wire extender?
I have a full race manifold with a 30r and since the 02 is further down the d/p the 02 sensor wire just isn't long enough to reach the connector in the engine bay. I tried soldering in an extension but I couldn't get the tin or aluminum type wire to solder for anything. Does anyone know where I could get maybe a 12" or 16" plug n play extender? Thanks!
Old Dec 5, 2012 | 07:43 PM
sktng22's Avatar
i extended mine no problem with soldering the wires in. try using flux
Old Dec 14, 2012 | 01:52 PM
BlowMeOff's Avatar
Yea I tried using a ton of flux and it held them together but the solder joint is NOT pretty and I'm starting to believe it's having a bad connection because I'm throwing a CEL for the 02 sensor and it's brand new. There has to be someone out there that makes a plug 'n play harness for this.
thedru13
Sep 4, 2011 09:49 AM
Tokuisport
Sep 27, 2010 05:09 PM
widge
15
May 4, 2010 07:52 PM
Dr. SS
Jul 11, 2008 04:57 PM
Profoxcg
11
Dec 28, 2007 07:55 AM
