Where to buy a replacement Evo 9 turbo?
Thanks to all for your answers.
I think I will buy an FP HTA71 from forcedperformance.net, but in their website they offer change the compressor cover, from 64 to 84 mm., with no charge. What will I gain with that?, It's recommendable?. I like my car seems OEM at sight.
Otherwise, If I install that turbo, do I need change other things, like injectors or stock (motor) will be enought for 300 AWHP?
Greetings.
Greetings.
Greetings.
Greetings.
you're running a IX stock block? you're good to well over 400 HP.
.....I think I will buy an FP HTA71 from forced performance .net....in their website they offer (to) change the compressor cover....to 84 mm. with no charge.
What will I gain with that?, It's recommendable?. I like my car seems OEM at sight....If I install that turbo, do I need change other things, like injectors or stock (motor) will be enought for 300 AWHP?......
If you were to change to the 84mm cover, then you would need a different intake tube(hose) from the MAF sensor outlet to the compressor inlet as well. So, that would be an additional expense.
If you order the HTA 71 with the stock compressor cover from FP, then it will look totally stock and you won't need to buy a new intake hose. Your car is an Evo IX, right?
You will definitely need larger injectors and a tune when you install the FP 71HTA. Furthermore, that Cusco inlet hose will not work with the larger 84mm FP Surge Port cover which has a larger diameter compressor inlet than the 64mm stock appearing cover. So either you order the FP 3.25"- 84mm inlet tube($99) in addition to the 84mm FP Surge Port compressor cover, or you stick with your Cusco inlet hose and the 64mm stock appearing compressor cover.
In the mods that you listed above, you did not include a higher volume fuel pump. Are you still on the stock fuel pump? When you switch to the 71HTA you will need a WALBRO 255 l.p.h. pump. Also, I would ditch the APEXI air filter for either a AMSOIL, Perrin, or K&N.
For injectors you will need larger than 680's or 720's. Might as well go 1150cc FIC's(Fuel Injector Clinic). At the very least, I think that you'll need the 850's.
Why do you think I must change my air filter?, There is something wrong with that brand?
Greetings.
Need more power
Hi sorry for jumoing in i have a evo 4 with a evo 8 engine just recently bought it i was told it had 380 bhp but a dont belive it to b honest what can i do to get more power with out breaking the bank will a evo 9 turbo help it already has a walbro fuel pump
98autogstspyder
657
Apr 27, 2022 01:48 PM
WTB[West]: WANT TO BUY: 2003 - 2006 EVO OEM Intercooler
05-EVO-GSR
Feb 26, 2017 03:27 PM
w8less1der
12
Jun 17, 2015 11:19 PM
Green_Bandit
Lancer Aftermarket Forced Induction Tech
39
Sep 5, 2013 04:13 PM
