How an aluminum head is pressure tested for cracks.
Old Dec 11, 2012 | 07:59 AM
BogusSVO's Avatar
Thumbs up How an aluminum head is pressure tested for cracks.
The subject head is a 5sfe Toyota DOHC
The procedure will be the same for any head.
First all the old gasket material has to be removed around all the water ports in the head.
Head gasket, thermostat, any ports that flow water.
This procedure is usually done after the head has been checked for warp.
Once that is done the head is placed in the pressure testing fixture.
Next the proper test plate is selected from the stack.
This plate fits this head.
See how it covers all the water ports on the head deck.
Next the clamping bars are placed over the head and tightened down.
any other water ports are blocked of with plates or plugs. One plate has an air fitting so compressed air can fill the water jacket.
On the right end of the head.
Compressed air fills the water jacket, appox 30psi.
Soap water is then sprayed over the head, Looking for bubbles from a crack.
Another side.
Great care is used in the combustion chambers, and all runners, along with the top of the head.
This head was good and showed no signs of cracks for coolant to leak from.
Old Dec 28, 2012 | 06:18 PM
93rx7fd's Avatar
must be nice to have these tools! lol nice write up
Old Dec 28, 2012 | 06:33 PM
WikdEvo's Avatar
Interesting. Thanks for sharing this info.
Old Dec 28, 2012 | 09:21 PM
Black Reaper's Avatar
At the shop I work at we pressurize the head while it is submerged in a water tank so its a little easier to see than just soap and water.
Old Jan 3, 2013 | 09:09 AM
BogusSVO's Avatar
Sounds like the "AXE" set up, I have used that system before.
To me it is a pain to keep the tank clean and not reaking.
kozmic27
Evo X How Tos / Installations
32
Oct 28, 2019 04:39 PM
motion3131
For Sale - Cars For Sale
32
Jul 18, 2014 01:26 AM
BogusSVO
Dec 7, 2012 04:49 PM
BogusSVO
Dec 6, 2012 08:07 AM
nollij
Member Unresolved Disputes
May 14, 2012 09:24 AM
