Manley valvetrain users/installers; please help
Old Dec 16, 2012 | 06:05 AM
Evo VIII 4o1's Avatar
Hi, i bought the following item from somebody:
4G63 - PRO SERIES VALVE SPRINGS and RETAINERS KIT part#26125
My question is, are all the valve springs and retainers the same, as in they can be used on both the intake and exhaust side, or are they side specific? Also, is there a certain direction the valve springs should sit on the head or are the wound up the same on both ends so doesn't matter if they're up or down.
Posted from Evolutionm.net App for Android
Old Dec 17, 2012 | 08:46 AM
BogusSVO's Avatar
Yes the springs are the same for intake and exhaust .
They are not a variable rate spring, so there is no top or bottom.
They should be a single valve spring with a Ti retainer.
https://www.evolutionm.net/forums/en...ring-info.html
Towards the bottom of the post, you will find the kit part number.
420a-t
Feb 25, 2014 07:25 PM
SDevo13
Jul 17, 2013 07:00 PM
BogusSVO
Jul 9, 2013 07:12 PM
sLowEvX
May 4, 2012 05:46 AM
