Really Fed-up with My Super Rich AFR whenever Immediate Full Throttle!
Old Jan 3, 2013 | 07:54 PM
BkzProblem's Avatar
Originally Posted by foxbat
If the car is knocking at normal fuel pressure, then you need to tune the knock out, likely by reducing timing in knock areas, increasing fuel pressure is not the best solution! You can always add fuel through fuel tables in case the mixture is lean in certain areas.
^^^ what he said.. If your knocking at stock fuel pressure then you need to address that problem first.
Old Jan 4, 2013 | 03:38 AM
jameswwt's Avatar
Thanks Guys...
Old Jul 18, 2018 | 02:14 PM
TariqEvo's Avatar
I am going through this same problem when switching to tephra v7, any ideas?
ReidFletcher
Apr 27, 2017 01:03 AM
jameswwt
Oct 19, 2012 11:21 PM
jameswwt
Aug 5, 2012 08:46 PM
Grif
Mar 12, 2012 07:29 AM
loppad
AEM EMS
Oct 7, 2008 12:18 PM
