can you mess up the clutch by jacking the car up in the wrong place?
my car was jacked up by the splash gaurd underneath, as i was told that there was a crossmember above it that would support the weight of the car.
needless to say this completely mangled the splash gaurd itself and the screw that held it in.
a day later, i went to the track and my car was not shifting into 4th very well. The car would grind unless i was super slow with the shift, and after a while, it wouldn't not go into gear at all unless i double clutched it.
the question is: can jacking up the car at the wrong point mess up the clutch / tranny in a way that can induce grinding / general transmission failure, etc?
I had the dealer put in a stock clutch, and now the problem seems to have gone away, the gears do not grind anymore although they are still a bit difficult to get into gear.
opinions ? suggestsion?
Man i think it's your syncro's. I had the same problem. shifting into 4th and 5th gear. I took mine to union Mitsubishi in Korea town last week and they are changing the 3rd, 4th, and 5th gear syncros. I get it back tomarrow. Give there service department a call tomarrow, I'm positive they will change them for you under warrenty. there number is 213-368-1900 ask for Gerome.
i don't remember a gerome working there, only this older asian fellow and a hispanic guy.
how long was the turnaround time?
What mods did you have when you brought it in?
However, i'm not sure why replacing a clutch would get rid of the problem, but it has (for now, knock on wood).
Originally Posted by alex_alex
were they easy to deal with?
Yea the older asian guy is Gerome.
There pretty cool about mod as long a the mod you have does not directly effect the problem your having.
It's worth giving them a call
I don't know, I thought the same when I first met him. He's Korean if that makes a difference.
Yeah, my first reaction was that this was definately a synchro problem.
Randal
20
Dec 7, 2012 12:54 PM
pb91
Jun 8, 2011 02:44 PM
