Anyone tried Piper cams?
Old Mar 8, 2004 | 07:37 AM
QuantumEVO's Avatar
The Piper cams require valve springs regardless. We sell the Ferrea Spring kit which I seriously doubt is going to be stressed by those sets. They have much more aggressive profiles for solid lifters as well.
Mark
www.Quantum-Racing.com
Old Mar 8, 2004 | 08:08 AM
Shahul X's Avatar
how much differance in price is the race and rally kits from Piper? worth it on a car that isnt planning on alarger turbo?
-shahul
Old Mar 8, 2004 | 08:26 AM
QuantumEVO's Avatar
All Piper cams are the same price on EVO's.
Mark
Old Mar 8, 2004 | 08:34 AM
en1gma19's Avatar
the extra money may not be worth it unless you're planning a turbo upgrade. eventually i plan or running 3037, gt35 or some equivalent 'large' turbo. I want the extra lift to help spool it. stock turbo may not benefit quite as much
Old Mar 8, 2004 | 11:41 AM
Guack007's Avatar
Would full boost come on earlier with the rally cams on the stock turbo? How much sooner at -3 Degrees (I heard this helps)??
Old Mar 8, 2004 | 01:10 PM
QuantumEVO's Avatar
Actually, the European fellas recommend the lesser lift (Ultimate Road) for bigger turbos. Big lift can cause more lag if you go too far. That is their opinion, anyways. Camgears can be used to shift the power band one way or the other.
I won't comment on spool effects of stock turbo since there are too many variables involved. The cam gears can make a noticeable improvement in spool. Retarding EX and advancing IN helps with spool the most. Retarding both helps with top end.
Mark
Old Mar 8, 2004 | 06:47 PM
Guack007's Avatar
Thnx =)
I cant wait for mine and will definatly be in touch when Im ready for cams.
Piper747
Mar 26, 2009 06:24 AM
EVO Scotland
23
Apr 14, 2008 11:23 AM
RALLIART/LANCER
61
Sep 27, 2006 12:45 PM
4ringturncoat
13
Jan 24, 2006 06:27 AM
