2 disc clutch for evo 8 wich one?
I have been searching around a bit for a bolt on clutch for evo 8 but i haven't really found anything yet.
Shep trans has a really nice clutch setup (quartermaster 2 disc)
But quartermaster doesn't have bolt on for newer evos.
So is there any easy way to rebuild the clutch fork so it pushes instead ?
After going through the OEm clutch, a Comp CPlutches stage 2 (horrid) and South bend DXD (Decent), I bit the bullet and installed a Cabonetics twin disk. It comes with the hardware for the push conversion.
My Evo is now a dedicated track car, 7K+ RPM shifts every lap, over and over. The carbonetic drives almost like the OEM clutch, but holds power without any issues and shifts like butter. Outside of the small diameter drag racing clutches, it has about the lowest rotating mass on the tranny input shaft availible in a full sized easily drivable clutch. And that mean great shift quality and better synchro life.
However, it does have one drawback. If you want to launch the car, the clutch has to be at operating temp or you will damage the carbon friction material. So it is not popular with the drag racing crowd.
The only question I have is why did i waste the time and money on those other clutches.
BlackOperative
Mar 22, 2017 08:13 AM
2006GSR
Aug 11, 2016 09:35 AM
SrBlacksheep
38
Jul 12, 2016 09:23 AM
2006GSR
20
Dec 28, 2014 04:23 AM
AngryEvo8
106
Nov 20, 2014 02:56 PM
