Need advise about turbo
Old Jan 11, 2013 | 07:24 PM
foxbat's Avatar
Originally Posted by Biggy VIII
The closest one is CBRD BBK Full ported. It will make about 480 flywheel HP on 98RON and spools 150-200rpm later than stock on 2.0 engine. You can push it up to 500 with meth or water.
All these turbos are state of the engeneering art and work perfectly, deliver best top HP. But they all suck if you love early quick peak torque of a squized out stock 9turbo and care about lag. There is no miracles. There is always Spool VS Peak HP.
PM me if you have any questions.
Some manufacturers tried to make best of both spool & peak with some success, a good example is the HKS GTII, I've tested it on an 2.0 Evo8, reaching 420whp (27psi) spool 'felt' very close to stock. But I never got the chance to compare it to a stock turbo on the dyno.
Old Jan 11, 2013 | 11:20 PM
Biggy VIII's Avatar
Originally Posted by RussellDaniel
...and learn to downshift lol. You won't have turbo lag then.
Lmao... Downshifting as a llifestyle... ))
Old Jan 12, 2013 | 01:12 AM
keath's Avatar
Originally Posted by SRT4toEVO
I dont think there is going to be a turbo "close to stock spool" making 450-500 hp.
Made 490 with faster spool than stock, hks gt2 with er2.4.
Old Jan 12, 2013 | 02:18 AM
foxbat's Avatar
Is it actually faster in spool than stock? Do you have a dyno sheet or at least remember the spool rpm range?
Old Jan 12, 2013 | 03:07 AM
keath's Avatar
https://www.evolutionm.net/forums/ev...4-hks7460.html
Here you go 4 th gear run so maybe not as fast as stock
Old Jan 12, 2013 | 03:19 AM
foxbat's Avatar
Amazing! What was the boost level & what fuel did you use?
Is the engine modified or still with stock internals?
Old Jan 12, 2013 | 04:04 AM
RussellDaniel's Avatar
That's awesome Keith!
Old Jan 12, 2013 | 07:52 AM
mrowka's Avatar
From: Driving ten under in the passing lane, right turn signal on at all times.
Remember Хмель is in Russia, where fuel may be a bit different from what the average frustrated American is used to.
TURBO_S2K
32
Dec 26, 2013 01:18 PM
kamote2000
30
Jul 10, 2013 08:33 PM
winkdogydog101
May 8, 2011 10:18 PM
Baxtersevo
Apr 4, 2011 03:36 PM
racer135
13
Apr 28, 2009 02:12 PM
