Need help with a decision
Old Jan 4, 2013 | 10:17 PM
kevin8086's Avatar
So I have 200 to spend. I just bought a ported used jb fp red. Question is do I spend the 200 on the 84mm cover or getting the exh mani, turbine housing and o2 housing ceramic coated? I have all other supp mods
Old Jan 4, 2013 | 10:51 PM
sktng22's Avatar
84mm cover, you could always ceramic coat everything later
Old Jan 4, 2013 | 11:03 PM
kevin8086's Avatar
Lol. No matter what I would have to take everything off to do either mod later. Just wonder what is better money spent now
Old Jan 5, 2013 | 07:43 AM
mt057's Avatar
I found that the cover makes a great sound and helps with surge when boosting 28+ psi. I did not notice an increase in spool or power when I made the switch but loved it non the less. Smoothed out my boost curve.
The coatings should help with underhood temps which are always a concern especially when hitting the road coarse.
Old Jan 5, 2013 | 08:17 AM
KevinBoosted's Avatar
I've never heard that you have to get the coating? IMO I would get the coating however, just from my experience of overheating and it does cause lots of damage that is hard to diagnose and fix
Old Jan 5, 2013 | 08:50 AM
evo8426's Avatar
Save the money for something that you may need later.
Old Jan 5, 2013 | 09:50 AM
kevin8086's Avatar
the only thing i would need later is an engine build if this one lets go. im doing cams, springs, seals, turbo, injectors, tune. guess i still need a ported intake mani and throttle body.
Lorenzoridesbmx
Oct 10, 2013 11:07 AM
abazaba410
Mar 24, 2013 05:15 PM
GTijoejoe
Oct 3, 2012 10:09 AM
robyn402
Sep 18, 2012 07:20 PM
