Rebuilding; sensor replacement questions
Old Jan 5, 2013 | 09:41 AM
low_evo8's Avatar
Hello everyone!
So since tax return time is right around the corner I will finally be able to finish my 2.4l build. The questions I have are; while everything is torn apart, should i replace the cam angle sensor and crank position sensor? I would hate to have to get back into the block and pull everything to do this replacement. I dont have access to an ocsilliscope to test the cam angle sensor. They currently have approx. 70k miles, and the reason im rebuilding is because of a spun rod bearing...just to give a brief background on the parts. And if there are any other sensors in which you guys could recommend that i replace while doing this would be a big help. Thanks!
**And if anyone has a lathed down balance shaft or good cond. front case+oil pump I could use one**
Thanks again guys!!!
Old Jan 6, 2013 | 07:28 AM
lowevo8's Avatar
bump
Old Jan 6, 2013 | 05:57 PM
barneyb's Avatar
This question is kinda like where people write in asking how much stuff to replace when doing 60K maintenance. To know, like a fortune teller, you'd have to be able see the future. In general, I'll venture that anything with questionable wiring should be replaced.
Old Jan 6, 2013 | 07:05 PM
TommiM's Avatar
I think you will be fine not replacing them. If they failed your vehicle would have drivability issues, so if you don't have any related to those sensors, why replace them.
whatever210
Oct 19, 2015 07:18 PM
TechyEVO
May 18, 2015 12:43 PM
evole97
Sep 19, 2014 02:13 PM
galantman03
30
Mar 10, 2014 07:57 PM
UKFive
Jun 6, 2012 07:19 AM
