Injector Size Question
Old Jan 5, 2013 | 09:32 PM
BDecker9's Avatar
So I am upgrading the turbo to an Old School FP Green, and the seller (Member here on EvoM) is including some FIC 680's with the turbo. My goal is right around 350-375whp. My question is.... With the mod list below, would this be feasible?
New Setup:
Old School FP Green
FIC 680cc Injectors
Walbro 255
Stock Block
Stock Head
ETS 1.50" Tubular Manifold
Injen Intake/UICP
ETS LICP
TurboXS FMIC
Muse 3" Exhaust
Muse O2 Dump
Test Pipe
TurboXS MBC
Dyno Tune (Granite State Dyno)
Previous Setup:
Muse 3" Exhaust
Test Pipe
Injen Intake/UICP
ETS LICP
TurboXS MBC
Walbro 255
Stock O2
Stock Injectors
Stock 8 Turbo
Stock Block
Stock Head
Tuned @ Granite State Dyno (274hp/258tq)
When it was tuned before, it was a very conservative tune on a very tired stock evo 8 turbo.
My biggest worry is the injectors will be at a high duty cycle, causing the pump to work a little bit harder than it's supposed to. Worst comes to worst, I can go with 1050's but I'd rather save the money for now
Old Jan 6, 2013 | 10:04 AM
Craig King's Avatar
Please use the correct section.
https://www.evolutionm.net/forums/ev...drivetrain-22/
Old Jan 6, 2013 | 03:17 PM
BDecker9's Avatar
Originally Posted by Craig King
Please post something useful if you're going to post at all.
This is the tuning and results forum. I'm asking about tuning and whether or not I'll make a certain amount of power off of a setup.
If the mods don't like it, they can move it.
Old Jan 6, 2013 | 03:27 PM
ReaperX's Avatar
The real question is what is your end goal? How much do you want to stress the equipment? Is this for 93, or e85? For me with a whp goal of 350-375 680's don't offer you a lot of head room. If you're not wanting to through down coin on the 1050's, 950's or 850's are cheaper and will give you some head room.
Old Jan 6, 2013 | 03:47 PM
Biggy VIII's Avatar
680 will work fine for your old school green on 93 octane, but will not leave any head room for the following upgrades.
as for fuel pump.. its not about your injector duty cycle, but about amount of fuel needed. 95% of 680cc or 65% of 1000cc doesnt matter, that will be about the same amount of fuel per minute.
Old Jan 6, 2013 | 04:12 PM
lude2evo's Avatar
^^^^^ agreed. having injector and running out of pump wont do any good
Old Jan 6, 2013 | 06:34 PM
BDecker9's Avatar
It will be on 93 octane. We don't have E85 up here (Too cold in the winter)
My ultimate goal for now is 350-375whp until I get the block and head built. I know the FP Green is capable of alot more, but I won't be pushing it past 400 without motor work done to it.
The fuel pump should be fine, I think. IIRC, people are making more than 500+ on a single Walbro.
Thanks for the input guys.
Old Jan 6, 2013 | 07:17 PM
Craig King's Avatar
Please follow the rules before posting. This is not a section to ask about tuning - it is for posting dyno tuning results.
Originally Posted by Noize
To start a new thread in this forum, a Dyno or DLL graph sheet must be posted within. Please do not start a new thread if you don't have a graph, or it will be removed.
If you are not posting a graph, do not use this forum! We have an Engine Management and Tuning forum located one slot below this.
Old Jan 6, 2013 | 07:21 PM
gomcar25's Avatar
311hp on93....see mods
Old Jan 6, 2013 | 07:32 PM
BDecker9's Avatar
First of all, I didn't mean to start a post in the tuning results forum, I thought I was in the "Engine Management/ECU Tuning" forum. Second of all, if the moderators don't like where this is posted, they are more than welcome to move it. And last but not least... Do you post stupid **** on people's threads to get that many posts? Or do you actually contribute to this community?
Are you running an FP Green?
Old Jan 6, 2013 | 07:41 PM
AreSTG's Avatar
epic facepalm on this section today.
Either that, or the Mod took a day off and we get to see what it's like with no moderation.
Old Jan 6, 2013 | 07:43 PM
gomcar25's Avatar
Nope, stock 8 turbo.
With the green you should easily pass 350
Old Jan 6, 2013 | 07:51 PM
BDecker9's Avatar
Yeah, it's a shame to see someone make a mistake by posting in the wrong section. He should be banned, huh?
Stock injectors? Or upgraded?
Old Jan 6, 2013 | 07:58 PM
whtrice's Avatar
Veteran: Air Force
I made ~350 whp with a OG green on a low reading Mustang Dyno on 100 oct gas. I was using 750 RC injectors at the time. You should be OK. I would try using your 680's first.
Old Jan 6, 2013 | 08:01 PM
BDecker9's Avatar
Thanks for the input. I'll give the 680's a try first
