I need some help with timing belt install - Evo 9
oh it's already done, thanks. I got the tension set just right to where when I flick the little wire they send in the tensioner, it spins freely about 15 times. To me that says the belt is perfect, and I've already spun the crank around about 20times just to make sure everything is good and all the timing marks line up perfectly.
the fact that the original belt was about 1 tooth off on the crank is why I was concerned and made this thread. I was expecting to unbolt everything and see a perfect set TDC but I didn't find that. I figured everything on re-install needed to be set to TDC perfectly, but figured I would ask if there was a reason it was slightly BTDC.
Anyways, thanks to those that helped me out
oh and in case someone searches for help some day - the trick I found to getting the water pump pulley off really easy is to have your cheater bar in the tensioner coming out the front of the car near the headlight. After you remove your motor mount, put a 1/4" ratchet with a 10mm socket on it down through that motor mount space and then while you're leaving over your fender, pull the cheater bar up with your foot and this will relax the belt. Then you can rotate the pulley to get the bolt in the area of the motor mount where you can easily loosen it and once it's in the right spot, let the cheater car down and that will tighten the belt and hold the pulley in place for easy removal of the bolts. Remove it and repeat for the other 3 bolts.
huh? You posted a day after I said I had done the starter bump and was done with that portion of the project and said "do it this way." You're a little late, captain
had you posted that advice before I got the bolt out I would have probably done it your way, but I was already done so there's no use in even talking about "the other way" and how great it is
Are you going to re-torque the crank bolt to spec using the starter? Im about to do mine so im wondering what tricks I should use and which ones are not good. I personally dont like the starter idea for the fact that how am I going to re torque the bolt to spec? I think ill do it by removing crank sensor, it seems easier and less bs.
If you out the car in 5th gear and wheels are on the ground the engine will not turn over and you can torque the Crank bolt using a tq wrench. It will move a little but until it takes the slop out of the transmission but then it will stop. Do not use the starter to install the Crank pulley.
fireroasted
20
Mar 27, 2017 08:17 AM
marinejensen
16
Jul 7, 2015 07:18 AM
heel2toe
46
Mar 24, 2015 04:17 PM
anthonypazsd
Jan 31, 2010 03:01 AM
easy say that now
