HG replacement questions
Old Jan 15, 2013 | 02:27 PM
fjm9898's Avatar
It appears i have a blown HG. (water coming out the back of the engine and oil in Cylinder #1) Compression was fine at 150PSI across the board.
my questions are as fallows:
I obviously should do belt and anything else while i have the head off. any good timing kits out there you recommend? my times was just done 15k miles ago, but oh well.
engine had APR head studs put on it when the head was off 15k miles ago. Can those be reused or should they be replaced? (my other car says studs should be replaced when head removed so i question this car on that too)
I assume OEM HG is still the best option for OEM bottom end?
Old Jan 15, 2013 | 03:12 PM
Blue91lx's Avatar
I would definitely do a better stud like an H11 or L19 so you can reuse them.
Old Jan 15, 2013 | 03:20 PM
mdsevo06's Avatar
Belt does not have to be replaced, you can zip tye the sprokets to the belt and remove from cams, assuming you replaced the belt 15K ago. New head studs for sure and a head up gasket kit.
Old Jan 15, 2013 | 03:40 PM
car_nut15's Avatar
Stock head gasket is very good. I torqued my arp's to 110 ft/lbs and never had an issue.
Old Jan 15, 2013 | 11:01 PM
Ted B's Avatar
The studs can be reused IF and only IF they were installed as per ARP's instructions and NOT overtorqued. If a stud yields even slightly from overtorquing, it's ruined, and will often cause a HG failure.
In no case should you do this:
... which aims to resolve a problem that doesn't exist by creating another, worse problem.
Old Jan 15, 2013 | 11:12 PM
sktng22's Avatar
Maperformance sells a good timing belt kit
Old Jan 16, 2013 | 03:49 AM
Blue91lx's Avatar
If you over torque your studs the head will normally develop small pressure cracks on the nut surface.
10isace
62
Oct 6, 2013 10:29 PM
Czarcasm
Jul 16, 2013 09:23 PM
ba109296
Dec 31, 2012 11:34 PM
Dream Came True
15
Jul 10, 2012 01:04 AM
DFelton
16
Oct 14, 2010 07:19 PM
