Evo VIII Tech Help - Please
Old Jan 21, 2013 | 11:25 AM
DaEvoBull's Avatar
Question Evo VIII Tech Help - Please
This weekend I was changing my oil and ran the car w/ the hood open.
I found that behind the oil filler cap on the valve cover I have pressure escaping and the same thing on the RT side of the cover.
I was wondering what should they be connected to.
Any help would be great,
Thank ya'll
Old Jan 21, 2013 | 11:41 AM
michael knight's Avatar
The one by the oil fill should connect to the intake manifold right there. My guess is the manifold is capped off. The rt one by the cam sensor should be routed to the intake charge pipe. Once again, that is probably capped off as well.
Another solution, run a catch can with a breather vent/ filter.
Hope this helps
Old Jan 21, 2013 | 03:16 PM
DaEvoBull's Avatar
Thumbs up
Hope this helps
Thank you, so if they are just open should not be a big deal then.
Since my set up is due to my 420a to 4G63 swap I wanted to make sure something did not get missed,
Thanks again
Old Jan 21, 2013 | 03:20 PM
fastyouth1313's Avatar
The only problem your going to have is oil squirting out those holes and making it messy.
Get an oil catch can
Old Jan 21, 2013 | 09:21 PM
BEKevo's Avatar
First off, the check valve by the oil-fill cap is the PCV. And the one on the right hand right (ie looking at engine bay) sends the blow by throughout the intake track.
As they said above, connect the PCV to the intake manifold (i.e. injector #1) and connect the right nipple to the intake pipe (i.e. between MAF and turbo)
Old Jan 21, 2013 | 09:24 PM
BEKevo's Avatar
Hope this helps
Incorrect way of routing catch can lines.. There is NO breather lines or filters you can just use to cap or whatever.. There needs to be a vacuum source to both or youll have ****ty results.
Heres a link to proper catch can install.
http://www.dsmtuners.com/forums/arti...cv-system.html
Old Jan 22, 2013 | 06:53 AM
DaEvoBull's Avatar
wow, thanks for the replys lots and lots of good reading, ... I for sure have to find a Strong Mitsu shop here in SA,
Thanks again to everyone
EvO_essence
12
May 9, 2016 12:48 PM
planblink182
Oct 8, 2015 08:15 AM
damionl427
15
Oct 11, 2006 12:10 PM
EVOKing8
Apr 6, 2005 10:36 AM
pgmike
Lancer Aftermarket Forced Induction Tech
45
Apr 4, 2004 10:28 AM
