which pistons to use
Old Jan 24, 2013 | 08:40 PM
luislm21's Avatar
i will use 86mm new pistons for my car, and i want to know the about the compression rate
because i see pistons with 10:1, 8:1
and i want to choose, i dont know what to do
Old Jan 24, 2013 | 08:57 PM
sktng22's Avatar
your better off with 8:1 for all around uses
Old Jan 26, 2013 | 09:22 AM
Abacus's Avatar
I'd personally run around 9:1 to 9.5:1 on a pump gas engine(non E85) Lower then that is used for high boost (35+) and will lead to a slower off boost acceleration off boost.
9.5-10:5 if you are going to run E85 all the time .
I'd also consider a stroker crank and different rods if you are building an engine. Huge gains are unleashed.
Evoloved
Dec 14, 2013 06:03 PM
bader
38
Jun 20, 2013 01:03 PM
boosted91t
Dec 26, 2012 08:41 AM
3grst01
Oct 30, 2012 11:35 AM
Aby@MIL.SPEC
Apr 26, 2007 06:55 AM
