EF3 + Stock Ex. Manifold - To port, or not to port?
Old Jan 31, 2013 | 03:28 PM
Strict7gsr's Avatar
You cant go wrong with MAP man great parts and excellent porting + coating services
Old Jan 31, 2013 | 03:32 PM
getsideways's Avatar
Ive run the divided MAP downpipe with great results(Check dyno section/EF results thread) on this EF3, Im also running the stock (MAP Ported/coated) Exhaust manifold.
Research MAPs porting they are probably the most in depth and do far more then hand dremil the cast manifold, Couldnt believe my eyes after getting mine back and looking down it.
Old Jan 31, 2013 | 04:03 PM
evotuner04's Avatar
15 Year MemberLikedLoved
either or is really going to do the trick, i'd say map 02 if your staying stock housing or if you want to go all out get the wastegate dump
Old Jan 31, 2013 | 05:26 PM
boostedwrx's Avatar
Best spool you will get will be on the ported oem manifold. I run a ported stocker with MAP 3" o2 eliminator dump.
Last edited by boostedwrx; Jan 31, 2013 at 06:45 PM. Reason: giving MA credit for their dump
Old Jan 31, 2013 | 06:28 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
TiTek or Invidia IMO.
MAP stuff is top notch, but I haven't seen too many builds running their O2 housings.
Old Jan 31, 2013 | 06:44 PM
boostedwrx's Avatar
I remember the MA SS o2 housing, must have been the rev 1, looked exactly like the Titek o2 housing, which many have made good power on. I checked the site and the rev 2 looks dif now, wonder why.
Old Feb 1, 2013 | 12:01 PM
veilside prius's Avatar
I would go with the Titek V2. Had one installed last week along with getting the stock exhaust mani ported. I paid $185 for the porting which included removal and installation (also had turbo swapped out).
Old Feb 1, 2013 | 12:27 PM
DisgustipatedM3's Avatar
I can't stop laughing at your username. Absolutely comedy.
Old Feb 1, 2013 | 12:54 PM
lol I forget I have a funny SN.
Old Feb 1, 2013 | 02:20 PM
Craig King's Avatar
I'll have to look for your thread then. I'll be running the EF3, ported stock manifold, ported turbine housing and divided O2 housing on 93oct. My only hesitation is the sound from the open dump tube.
I feel silly asking this, but are you happy with the 3" O2 divided housing? Do you DD your Evo?
I DD my Evo currently... and for the most part, I try to keep a low profile (as low as possible for an Evo). But I'm really concerned that the O2 dump is just going to sound like a huge exhaust leak whenever it opens at full boost. I don't want to sound like I'm racing around with a hole in my exhaust.
Old Feb 2, 2013 | 06:16 PM
boostedwrx's Avatar
I don't DD mine but I really enjoy the MA o2 eliminator dump. Honestly I never hear it unless I go WOT. I believe I'm running the 25psi actuator so unless I see >20 psi I never hear it. I can give the car half throttle on the freeway and because of the Synapse bov it perfectly maintains 10-15 psi. With the 2.4 I can do a lot with part throttle. When I go WOT and 600+ whp the dump sound just adds to the terror
Old Feb 2, 2013 | 08:38 PM
evotuner04's Avatar
^v8s cant handle the terror
romogst
14
Dec 14, 2014 08:36 PM
nzevo8
Sep 20, 2014 04:51 AM
TougeGod7
24
Sep 18, 2013 05:47 PM
Craig King
26
Jun 11, 2013 01:05 PM
EvoIIIAj
12
Jul 20, 2012 08:17 AM
