Half Rad Question
Old Jan 28, 2013 | 12:24 PM
5LEEPERISAH23I's Avatar
Half Rad Question
I keep changing my mind about going Stand. T3 or Front Facing.
Am i more likely to push coolant if i do a 1/2 Rad. I feel like most people that use 1/2 Rad. always have issues with them in some kind of way.
Will it be more likely to overheat?
Or be more likely to push coolant?
Old Jan 28, 2013 | 10:46 PM
BEKevo's Avatar
Depends what your intentions are. If you're autocrossing or tracking it a full size radiator is your best bet or a good quality aluminum half radiator (ie Not eBay) But since you said forward facing, I think your intentions are drag racing... In that case, you'll be fine. I've had great luck with my Mishimoto half radiator, (not the most favored radiator on the forums because of other vendors.... but the price and warranty beats everyone) i autocross and do canyon runs frequently....
Old Jan 29, 2013 | 03:14 AM
silentkiller's Avatar
Im running on half rad for nearly 2yrs..drive for 3hrs non stop on 100 degrees hot weather with no issues.Im on Civic Koyo.
Old Jan 29, 2013 | 03:49 AM
whiteEvo08Y's Avatar
I am running the Small Koyo and F-A-L Fan kit for a year now with 100 degrees plus beautiful humidity and still running strong.
Old Jan 29, 2013 | 10:45 AM
hmm interesting. i just dont wanna run into overheating problems in stop and go traffic ect.. i guess that answers my question
Old Jan 29, 2013 | 11:11 AM
korizmo's Avatar
This half radiator was cool with all the room. I first tried the civic half raditor with ebay fan. Big fail. Yeah the temp cluster gauge wont go high cause it just monitors a range, but once you start monitoring temps directly from the ecu its gets kinda scary. Then I switched to the koyo half rad with stock fan. Temps were down, but still didnt like the temps.
I never got stop and go traffic as we don't have that down here. Also I still have a/c if you remove that big condensor i'm sure the temps will be lower.
Civic rad with ebay fan
cruising temps - 190-212 depending on outside temps
sitting at the light temps - around 200
boosted run 0-100 mph - around 250
Koyo with stock fan
cruising temps - 188-205
sitting at the light - 188
boosted run 0-100 mph - 226
Megan Giant radiator with stock fan
cruising temps - 178-186
sitting at a light - 180's
boosted run - 208
Best review i'm gonna give
Old Jan 29, 2013 | 12:29 PM
Svendiesel's Avatar
Half Koyo/FAL fan on my car too, temps are never ever hotter than they were with my full width Mishimoto rad or the stock rad.
Old Jan 29, 2013 | 10:19 PM
evo7_8u's Avatar
aslong as you get a decent radiator with a decent fan you'll be fine , i have a koyo 1/2 width radiator with a Blox 12inch fan and its fine.
kwpilot
Feb 20, 2023 09:29 PM
chassis87
29
Jan 15, 2017 04:02 AM
08SSL
11
Sep 28, 2016 08:13 AM
RalliartN
Mar 24, 2016 07:08 AM
