Need Help : Compression Bad
Old Jan 30, 2013 | 04:43 AM
eus_evo8MR's Avatar
Lightbulb Need Help : Compression Bad
buddy, i am install cosworth gasket with headstuds Cosworth Ultra High Performance Head Studs are manufactured from H11 tool steel with 260000psi tensile strength, i go with 16kgm. and for the surface of head and block is good,
the problem is water at reservoir tank are 3/4 full and like buble on hot water, boost 30psi only. why this can happen?
i am already twice changed this gasket with the same brand, but twice is same condition
whats the recommend gasket for boost 35psi++ ?
anybody please help and sharing the information
thanks
Old Jan 30, 2013 | 06:54 AM
05blue8's Avatar
Race cars use the stock gasket. If you've redone the gasket twice and are having the same issue it's more likely the head and block you think are good in fact aren't. How are you measuring if they're "good" or not?
Old Jan 30, 2013 | 07:38 AM
HIS Motorsports's Avatar
Either the head is warped or you need to torque the head-studs down property!
Old Jan 30, 2013 | 04:21 PM
batty200's Avatar
I am wondering why you would say the head isn't torqued properly. 16kg/m is approx 115lb/FT. That is what most people recommend tightening tool steel head studs to.
Old Jan 30, 2013 | 07:24 PM
boost556's Avatar
I don't think your thread is in the right place!
Old Jan 31, 2013 | 08:14 AM
The head would have to be torqued down evenly and Re-torqued!
Old Jan 31, 2013 | 10:18 AM
jfogg's Avatar
go with a OEM headgasket and ARP studs, look up the tightening procedure / sequence.
howell
13
Jun 20, 2014 04:08 PM
njvlllrs
23
Feb 19, 2014 02:12 PM
eus_evo8MR
Feb 13, 2013 10:20 AM
eus_evo8MR
Feb 2, 2013 08:23 AM
