Need Help : compression crossed
Old Jan 30, 2013 | 04:44 AM
eus_evo8MR's Avatar
Lightbulb Need Help : compression crossed
buddy, i am install cosworth gasket with headstuds Cosworth Ultra High Performance Head Studs are manufactured from H11 tool steel with 260000psi tensile strength, i go with 16kgm. and for the surface of head and block is good,
the problem is water at reservoir tank are 3/4 full and like buble on hot water, boost 30psi only. why this can happen?
i am already twice changed this gasket with the same brand, but twice is same condition
whats the recommend gasket for boost 35psi++ ?
anybody please help and sharing the information
thanks
Old Jan 30, 2013 | 11:53 AM
cmspaz's Avatar
First off, can we get a mod list? What turbo's on the car? Stock 2.0?
The factory MLS gasket is perfectly fine for most applications, you can spend more if you want but there's little reason beyond being able to say you spent more on it.
Are you losing coolant in the process or does the reservoir just bubble? If it's not puking out the overflow tube chances are it's not a gasket issue and the air is getting in there some other way, as well as coolant flowing out. A leak, in other words.
And lastly, what're you torquing the head studs to? You said 16kg, which is 35lbs, and that simply can't be right. 35lb/ft is less than half of what they should be, some even recommend almost 3 times that on higher boost applications.
Old Jan 31, 2013 | 03:36 AM
eus_evo8MR's Avatar
cosworth block 2.2L
head cosworth big valve
pt6466 boost 31psi
cam tomei procam 270
reservoir just buble, and go high
16 kg/m = 115.7282216lb/ft
eus_evo8MR's Avatar
cosworth block 2.2L
pt6466 boost 31psi
Old Feb 1, 2013 | 09:21 AM
BogusSVO's Avatar
You say the surfaces are good.
Was both the block and head surfaced? If yes.. How were they surfaced and/or prepped?
It sunds like you have a small imperfection in one of the surfaces allowing compression into the coolant jacket
Old Feb 1, 2013 | 02:25 PM
Freaked ls3's Avatar
I agree! Was the head surfaced?
Old Feb 2, 2013 | 07:28 AM
eus_evo8MR's Avatar
But i an very sure the surface of head and block engine is very perfect condition, is thAt enough for the torque of head 115lb/ft ?
Old Feb 2, 2013 | 08:23 AM
BogusSVO's Avatar
I doubt the surface is perfect as you think.
If it was then you would not have popped the head gasket twice.
https://www.evolutionm.net/forums/en...-surfaced.html
https://www.evolutionm.net/forums/en...nder-head.html
EVOjunky
Dec 15, 2013 04:13 AM
eus_evo8MR
Jan 31, 2013 10:18 AM
eus_evo8MR
Nov 25, 2012 09:24 PM
eus_evo8MR
Nov 22, 2012 10:17 AM
