9RS transmission problem
Old Jan 31, 2013 | 11:56 AM
xmel012's Avatar
Hello. can not to switch 2,3,4 gear on 7-8 rpm. i have new stroker 2.2 without balance shaft and new clutch ACT. before stroker i did not have this problem . what is it????
Old Jan 31, 2013 | 12:04 PM
prowakeskater's Avatar
clutch. set a better, higher engagement point with your master cylinder
Old Jan 31, 2013 | 01:08 PM
xmel012's Avatar
but it was good with transmission before stroker. clutch as new
Old Jan 31, 2013 | 05:15 PM
hiboost2.0's Avatar
If the clutch is new you still need to adjust it. What wakeskater is a good idea try it out.
Old Jan 31, 2013 | 09:46 PM
xmel012's Avatar
explain me how to do it please?????
Old Feb 1, 2013 | 11:03 AM
analogEvo's Avatar
Their is a rod with a nut on it behind the clutch . Loosen the nut and adjust the rod to raise or lower your clutch pedal. Go to jacks transmissions website it explains how to do it and test your clutch to see if its dragging or not.
naplesevo
19
May 30, 2014 09:08 AM
tupac1
17
Apr 2, 2014 07:24 PM
fastassfourdoor
24
Jul 9, 2009 02:36 PM
nitroboy158
15
Aug 28, 2008 11:54 AM
dragers
Apr 6, 2008 11:57 PM
