low boost problem
Old Feb 5, 2013 | 07:18 PM
a4rontran's Avatar
low boost problem
I have evo 8. Recently, I notice the car only boost at 14.5 psi. My car was tune at 24.5 psi. We checked for boost leak, switching 3 port, check the tune map, and yet it still has the same problem. We unhook the 3 port to test the turbo, and it boost by itself fine. So now, I need help to see where else can I look to fix this problem. By the way, i have fp 71hta, 18psi wastegate actualtor from FP.
Thanks
Old Feb 5, 2013 | 07:34 PM
sparky's Avatar
Originally Posted by a4rontran
...I....check the tu sane....
What is this, please?
Old Feb 5, 2013 | 07:40 PM
a4rontran's Avatar
sorry, I just edit it. Could it be wastegate actualtor causing the problem?
Old Feb 5, 2013 | 07:52 PM
sparky's Avatar
It could quite possibly be the wastegate. Or, could also be a boost leak? Or, could even be a leak, or crack in the vacuum hoses and fittings.
Old Feb 5, 2013 | 08:03 PM
sparky's Avatar
When I say that it could be WG related, I do not mean that there is something wrong with the WG itself. WG failures do happen, but they are relatively rare.
If it does turn out to be a WG related issue, then it probably is a matter of improper adjustment and not a mechanical failure. Like I mentioned, there are sometimes material or mechanical failures of the flapper valve or the actuator assembly but they are very infrequent.
Old Feb 5, 2013 | 08:09 PM
a4rontran's Avatar
is there a way to adjust the wga while it's on the car? maybe i need to tighten it a little?
Old Feb 5, 2013 | 09:21 PM
sparky's Avatar
Yup. You have just hit the nail on the head. Shoot me a PM and I´ll walk you through the process.
Old Feb 9, 2013 | 03:06 PM
a4rontran's Avatar
^^^^Thanks for Sparky. I finally get some boost going. The problem was the WGA preload.
kirkklau
36
Mar 10, 2017 01:05 PM
blackedoutsrt
10
Nov 26, 2014 01:23 AM
Boostin Perform
Feb 8, 2014 08:44 AM
TS Dork
Nov 28, 2013 07:34 PM
usernameinuse
Jul 31, 2011 01:59 PM
