Overboost problem. Searched still can't figure it out...
So got my car is overboosting when its tuned for 22-23 psi but goes way over to almost 30 psi after 4-5k rpms.
Thought it was the actuator. So replaced with brand new turbosmart 14psi actuator. Still overboosted.
Hooked it up straight to the actuator and by passed the boost controller. Supposed to stay at 14 psi but still overboosts.
Replaced all new boost vacuum lines. Still overboosts.
What else could it be? What else could I check? This is driving me crazy and can't figure it out.
Mods:
O2 housing, dp, resonated tp, cbe
Ets intake with maf adapter and k&n filter.
3 port Grimmspeed ebcs
3 port map sensor
Turbosmart 14psi actuator
Mods:
3 port map sensor
Have you tried lowering the load for the 3 port ? Also you said you replaced the WG, where able to move the flapper by hand ? Any chance its getting stuck closed!
PearlWhiteX
May 9, 2016 08:05 PM
twinspoolin94
Oct 15, 2015 05:28 AM
