help me fix my evo
Old Feb 7, 2013 | 07:07 PM
dovelyy's Avatar
help me fix my evo
Ok so here is what I'm dealing with, while I'm driving when I get to around 3.5k rpms the rpms just jump up to like 4.5k then drop back down to like 4k then picks back up.
My turbo not under boost while this happens until it stutters then it only boosts to about 4-5 lbs...
plugs are good... is it a possible leak or coils?
any insight would be appreciated hopefully I explained this well enough, it's kind of hard to explain my situation.
Old Feb 7, 2013 | 07:23 PM
chamelieon's Avatar
if your still under the oem MAF then its very picky and everyone is going to tell to do boost leak test and make sure thats done before questioning anything else.
Old Feb 7, 2013 | 07:24 PM
flymx771's Avatar
Not really sure exactly what you're saying is happening, but sounds like your clutch is slipping. You mean rpms are going up and the car isn't accelerating?
Old Feb 7, 2013 | 07:26 PM
dovelyy's Avatar
yeah the rpms like stutter goes up from 3.5k to 4.5k then down to 4k then builds back up regularly
Old Feb 7, 2013 | 07:27 PM
dovelyy's Avatar
still using oem maf replaced my maf using a friends but it didnt change anything and I havent boost leak tested it yet but i dont think thats the main issue here
Old Feb 7, 2013 | 09:08 PM
craig05evo's Avatar
if you replaced the plugs, make sure you put dielectric grease on the indside of the boots. Just put some out of the tube into the boot and ring it around with a clean metal screwdriver (with the engine off of course).
Old Feb 7, 2013 | 10:11 PM
kamakazy_kid's Avatar
Sounds like your clutch is slipping. Time to look for a new one.
Old Feb 7, 2013 | 11:24 PM
Thore's Avatar
Even if it isn't the cause the problem, doing a boost leak never hurts. Always nice to find out you have a massive leak, fixed it and there ya go, +30 hp.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
scubaEVO
Jun 21, 2017 07:27 PM
tequila357
Feb 18, 2016 11:42 AM
Igaly1021
Nov 7, 2015 05:18 PM
BlueEvoEx
May 15, 2015 11:05 AM
