O2 housing and ex manifold studs and bolts
Old Feb 14, 2013 | 11:45 AM
Lukelis's Avatar
Question O2 housing and ex manifold studs and bolts
Interesting, are you changing studs and bolts if they are ok when you changing the turbo?
Old Feb 15, 2013 | 11:42 AM
Lukelis's Avatar
nobody changing turbos?
Old Feb 15, 2013 | 01:34 PM
evo8426's Avatar
New nuts, studs, and bolts are extremely cheap so I see most people buying new fasteners for new turbos.
Old Feb 15, 2013 | 01:45 PM
BDecker9's Avatar
Yes yes yes yes change them. I just ran into this problem not too long ago.
I swapped out my manifold (stock manifold to an ETS stock replacement) and re used the manifold studs. It lasted a couple of months and then the studs started to sheer off. I dealt with the exhaust leak for a little while. I changed out my turbo and O2 like 2 weeks ago and replaced all the studs/bolts/nuts and gaskets. Runs like a champ now with no exhaust leaks.
The whole setup as far as gaskets, bolts, nuts, washers, studs and such was around $300 IIRC from STM. I ordered from STM because they were the only ones that had all of the bolts/studs/washers/nuts/gaskets available. I wanted everything to show up in one box instead of trying to keep track of 5 different packages.
Let me know if you have any questions, I can go back and look at what I ordered to give you an idea
Old Feb 15, 2013 | 02:13 PM
pls1968's Avatar
OEM 02 housing bolts are 8-9 dollars a piece and the turbo ones are like 4 dollars. OUCH!
I know cause I just bought them
Old Feb 15, 2013 | 02:55 PM
Lukelis's Avatar
thanks
Old Feb 15, 2013 | 02:56 PM
Lukelis's Avatar
I cant check now, there is 2 studs on O2 side?
Old Feb 15, 2013 | 05:15 PM
pls1968's Avatar
I removed the studs and converted to all bolts.
jrsimon27
39
May 25, 2022 04:26 PM
2006EvoIXer
May 31, 2017 08:49 AM
cmillz1225
Jul 14, 2013 07:26 AM
turboDan
86
Oct 26, 2012 12:47 AM
GearedUp
Mar 18, 2012 06:29 AM
