Best way to make 450whp on stock bottom end?
Old Mar 5, 2013 | 02:50 PM
  #31
car_nut15's Avatar
Originally Posted by SilverLanEvo
I would not trust our stock tcase at 450 awhp...I suggest at least a shep stage 2 for that kinda power...
I made 613whp on a stock t-case and never had an issue. I would not expect it to last forever at that power level but it will go for a while. As for a boost controller a lot of guys like the 3 port solenoids so that they can control the torque curve better especially on the stock block. Speed density is supposed to free up some hp and help drivability. Im currently converting to speed density aswell.
Old Mar 6, 2013 | 02:10 AM
  #32
Guitarplyr's Avatar
stock t-case is quite durable, just have to take care of it. Keep a close eye on the fluid level, change the fluid religiously, and keep the drivetrain shock (hard launches from a standstill) to a minimum, and you should be just fine.
Old Mar 6, 2013 | 11:40 AM
  #33
jbkonis's Avatar
Clutch choices are tricky. I've been doing a lot of research and it seems as some of the Exedy units having trouble. I made 390WHP on stock placement GTX3071 and had to stop tuning as it started slipping on the dyno.
Old Mar 7, 2013 | 12:01 PM
  #34
JohnBradley's Avatar
Clutch choices are pretty straightforward for this power level-
Comp stage 2, either sprung or unsprung, race as needed (example of how it shifts)-
Old Jun 19, 2013 | 05:19 PM
  #35
RpVilleneuve's Avatar
Originally Posted by PatricksEvilEvo
+1. 450 isn't that hard. My mod list for you...
3" turbo back with test pipe
02 dump
MAP EF3 or FP Red turbo
Tube manifold optional (Toxifab FTW!)
FMIC+piping
coil on plug setup
Competition or Exedy clutch (do your own research!)
FIC 1100 injectors
fuel rail
Walbro 255 pump
Thats my setup minus the upgraded turbo.
subiekilla
16
Mar 3, 2017 02:17 PM
Ferp
Sep 26, 2016 05:32 PM
kmaqueira
Jan 4, 2016 11:08 AM
doncarbone
14
Dec 29, 2014 03:02 PM
ktk
Oct 21, 2011 07:57 PM
