stock boost solenoid harness
Old Feb 24, 2013 | 08:22 PM
EvoIXPilot's Avatar
The previous owner removed the stock boost solenoid and hoses when he replaced it with a greddy profec B spec 2. I'm trying to find it but can't visually see it. Where is the "base" of the harness, basically the opposite end that is coming out of the car or whatever part? I want to trace where the PO hid it.
Old Feb 24, 2013 | 08:30 PM
sparky's Avatar
Factory BCS location under the stock air filter box, or some such place.
Old Feb 24, 2013 | 08:36 PM
EvoIXPilot's Avatar
I'm actually looking for the harness that connects to the Oem BCS.
Old Feb 24, 2013 | 08:52 PM
sparky's Avatar
You can purchase a new, factory vacuum/boost hose assembly already preassembled with the factory T and hose clamps. It includes the all important boost restrictor orifices, at any Mitsu dealership for about $20.
Old Feb 24, 2013 | 09:39 PM
EvoIXPilot's Avatar
But the harness that connects to the boost solenoid I believe can only be cut in order to remove. I'm assuming he didn't do that and just hid it. If I know where the opposite end is connected to, I will be able to trace it. Without it, I can't connect the grimmspeed boost solenoid
Old Feb 25, 2013 | 03:13 AM
sparky's Avatar
Are you refering to the electrical harness? Most peeps leave it plugged into the solenoid. Sorry, but I misunderstood you. I thought that you were refering to the boost/vacuum hose assembly.
Old Feb 25, 2013 | 01:11 PM
EvoIXPilot's Avatar
Yep, the electrical harness. I don't see the connector end that connects to the solenoid anywhere
Old Feb 25, 2013 | 01:22 PM
ILuvJDM's Avatar
look under where the intake filter would be, or near the ACD pump. The factory BCS mounts right under the filter box
Old Feb 25, 2013 | 01:25 PM
ILuvJDM's Avatar
you can see my grimspeed 3 port in this picture. Follow the SS clutch line and it runs right towards the boost controller. You can see it mounted on that frame rail. The BCS plug comes off that harness that is above it laying flat on the frame rail
Old Feb 25, 2013 | 02:24 PM
EvoIXPilot's Avatar
[QUOTE=ILuvJDM;10680036]you can see my grimspeed 3 port in this picture. Follow the SS clutch line and it runs right towards the boost controller. You can see it mounted on that frame rail. The BCS plug comes off that harness that is above it laying flat on the frame rail
[/QUOTE
Just making sure I'm seeing it, its by the rail on the driver side?
Thx
Old Feb 26, 2013 | 12:54 PM
ILuvJDM's Avatar
yep, just to the left of the ACD reservoir
Igaly1021
Jan 13, 2017 01:15 PM
metallics2000
Oct 8, 2016 10:47 PM
domyz
Aug 3, 2016 10:48 AM
Lanart2011
21
Mar 27, 2016 06:13 PM
Siyah
11
Feb 22, 2004 08:40 PM
