The best ways to gain 100WHP on EVO 8..suggesstions
stop dreaming.
First off, adding fuel mods does not add horsepower.
You will have to add bigger injectors and likely a bigger fuel pump (or BAP) to make more that much power. Convert to E85 at least for your high boost tune, or just run race gas; up to you.
If you really want to make more power, do it right:
upgraded pistons/rods, build the bottom end.
Headwork, +1mm valves
GSC R2 cams
MAP Rev3 IM (or magnus?)
Bigger FMIC
See how far that gets you and then upgrade the snail, you need to either push the setup you got or build it bigger and have it be reliable.
GSC R2 cams
Bigger FMIC
lol agreed
If I were you and wanted to make 100 hp more without changing the turbo I'd go with gsc s3 cams, map o2 dump, e85, a ported intake manifold throttle body and a tubular exhaust manifold. That should be able to get you close to that and also keep you in the 2k range if you buy some parts used on here
First of all thanks for the great Ideas and opnions guys.
I'm out of the country and kinda busy this week, keep up with your good ideas - The moment I'll have the chance I'll get over the thread and answer all of your questions.
the fuel is 100 octane.
It looks like there is one opinion - E-85!
I cant really get the most out of the parts unless I change the fuel system - I'm really surprised that going over 500 HP has to include the e85 system, I took it in consideration but thought it is going to be the last thing I'll do.
Another question what about the OEM engine? how much power can it take - dont forget I said reliable- very important, still its a DD car!! so maybe what "scheides" suggested is the right next step, what do you think guys the OEM can bare that abuse - more than 600 hp on stock engine??
At the moment I'm thinking about CBRD/JMF TwinScroll Manifold and their O2 Housing - after reading what CRBD says regarding the O2 housing they claim :"Most External dump designs are improper and cause boost creep at high rpm and load" what do you think about that - map o2 external dump or the CRBD o2 dump or another dump that you suggest? (the money is not an issue looking always for high end quality parts)?
dont know really why but till these thread I always considered AMS as the best brand ever - guess I was misleaded by mechanics.
just to make things straight:
turbo - not intending to change at the next 6 months at least
cams - wish I bought the S3 instead of my Kelford's 272
engine build- depands on your answer, if the stress of putting so much power on the stock than I'm not gonna add more power and rebuild my engine - this is the most important issue at the moment!
e85- not at the moment
Intake manifold and TB- This is what started the thread - I wanted the Ams f1-I talked to a couple of mechanics including AMS and it was agreed that its too early for that- and I wont get the most out of it at my current setup, same about TB.
Injectors - thinking about the 2000cc any suggestions? what else do I need in order to make them work - pump, fuel rails or a race fuel? if it's the last I'll pass on that- logically why would I add more fuel if I dont add more air(bigger turbo)- my 20G is almost on the edge considering reliability needs.
SO, at the moment I'm thinking about:
GSC S3 cams
CBRD Big O2 Housing/Downpipe Combo
Good tune
what do you think will I get another 100?
Thank you very very much guys I'm learning a lot from your answers, just want do it right and make the most out of what I have.
sorry for being annoying
)dont know really why but till these thread I always considered AMS as the best brand ever - guess I was misleaded by mechanics.
GSC S3 cams
Good tune
You are not going to get another 100whp from your current turbo, it just is not going to happen.
GSC S3 are a good option since you are looking to make high power.
I wouldn't waste money on the CBRD parts, you can find better alternatives and parts that are not priced sky high because they look nice. The price of just the dp/o2 combo is in the upper $800USD range. That is half the price of a turbo right there.
A good tune never hurts but you must remember that once you go over 400 torque you are risking blowing the OEM block because the rods cannot handle it very well.
To make an additional 100whp you need some magic dust or to change the turbo.
they claim :"Most External dump designs are improper and cause boost creep at high rpm and load" what do you think about that?
evo 8426 - can you recommend on some parts/brands?
Some of you are saying just switch the turbo but that is simply not enough - rebuilding the block at this point is just inevitable - cuz I really dont want to take the risk of cracking the block!
I thought the block could handle the extra power but looks like it aint
any suggestions for parts for the engine rebuild?
OG
63
Feb 6, 2014 10:44 PM
SrBlacksheep
13
Dec 1, 2013 09:09 PM
tscompusa
Dec 14, 2012 01:18 AM
